clutch slipping
clutch slipping
I had a spec 3 installed about 30k ago along with the drill mod to master and a new slave cylinder. My clutch will start to slip when i first take off or shift gears but then catches. Master or clutch going bad.
hmmm well there goes what i was thinking. Alot of times from what i understand if you dont get the flywheel machined down. Or replace it the clutch will slip alot sooner. You stated however you got a new one so im out of ideas
Oh yea, I got the spec 3+ and has worked great for me. I had to replace my stock clutch at 30k too. Which, at the time, I was pretty easy on the car. My car now has 550 to the wheels. However, I don't drag race at a track either. good luck.
