View Poll Results: Which Cam?
Voters: 39. You may not vote on this poll
Which cam?
Which cam?
I am torn between cams. I am thinking about going with the G5x3 or the Magic stick 3. I have a 346 LS1 with a LS6 intake, Long Tubes, underdrive pulley, 4.10's, six speed, and a ported throttle body. My buddy has a g5x3 and I was really impressed! The Magic stick 3 has a good rpm range. This is mostly a daily driven summer car. What do you guys think?
Feel free to add a different cam!
In other threads posing the same question, I've seen claims that the MS3 is more of a top-end only cam, where the G5X3 is designed to build power all over. Some of that could be changed by advancing the MS3 upon installation.
But if you are talking about a street car (primarily) then I would go for the one that benefits the majority of your use, over the one that may show some gains 5% of the time.
Retired Street Racer
Originally Posted by prostock_bigblock
I dont like the torque curve on most the MS3 dynos, just go and search for the H/C combos for the G5X3 u will see a bunch of ppl with 460+ rwhp & 400+ tq.
Originally Posted by Matt D
There is a difference between track numbers and dyno numbers. If you want to be a dyno queen, by all means go with whatever cam you feel makes the most power in that simulated environment. I chose the MS3, put down 360hp/321tq on a Mustang dyno and is proven on the track. My track numbers are in my sig, and click on the pic for my full mod list. MS3 cam only, auto with 3.42 gear & 17" MT drag radial, I ran consistant 10.8-10.9, and daily drove the car. Dyno numbers aren't always everything.
Good numbers - damn good numbers
If your going to compare the 2 , G5X3 should sit aside and let its big brother tango with the MS3 big brother goes by G5X4 . Believe theirs also G5XX's .
The few who voted custom grind versions need to enter in specs .
My vote custom grind around MS3 specs . XE-R Lobes
236 / 242 @.050 .602'' / .610'' 110+2 Lsa
I have choosen Thunder Racings 230/224. not even close to what I thought I was going to get. I guess thats the fun in building a car.
I went with the 230/224 so I could keep my 918 springs and what not. I also didn't want a high power band because this will be a mostly street car that I will drive everyday in the summer.
Thanks for the imput guys!
as u talking about results, look at the cam only section.
Originally Posted by hammertime
I realize your numbers were on a Mustang Dyno, but what kinda weight were you at to run in the 10's with those numbers? Good suspensions & Chassis I assume too.
Here is a link to what the car sounded like :
http://smg.photobucket.com/albums/v4...roTwisters.flv
