383 N/A Plugs
Old 10-14-2006, 01:50 PM
Evaporate's Avatar
Default 383 N/A Plugs
My 383/Trickflow heads will have 11:3 compression. Using this thread: https://ls1tech.com/forums/removed-locked-thread-graveyard/456380-spark-plug-reference-chart.html should I go with the Autolite AR3911? Doing a search, it seems that more N/A modded lt1 owners prefer the Autolites over the NGK. I will gap the plugs at .40 from what my shop instructs.
Old 10-14-2006, 02:18 PM
streetwarrior96's Avatar
yopu can go with either one they both are good. I have the NGK's no probs with them
Old 10-14-2006, 02:55 PM
1989GTA's Avatar
The Autolites have the cutback ground tip to help expose the electrode.
Old 10-14-2006, 03:25 PM
Evaporate's Avatar
I am not sure if the autolite AR3911 that I mentioned above is recommended for NA or nitrous setup.
Old 10-14-2006, 06:08 PM
9-Second Club
Ed Wright's Avatar
I use Autolite 104s in mine.
Old 10-14-2006, 08:01 PM
Evaporate's Avatar
Thanks everybody. Ed, I think that will be the one I go with. I don't plan to do nitrous.
Old 10-15-2006, 08:12 AM
moserman's Avatar
im using ac delco plugs from any GM dealership, ive had trouble with other plugs misfiring and was told to just stick to stock plugs.... havent had a problem!
Old 10-15-2006, 12:33 PM
Evaporate's Avatar
What are your mods?
Old 10-15-2006, 11:27 PM
moserman's Avatar
Originally Posted by Evaporate
What are your mods?
383 stroker from golen engines, ported heads, ported intake, cam, injectors, intake elbow, moroso CAI, full exhaust, roughly puttin out 500 crank horse
Old 10-15-2006, 11:36 PM
TwoFast4Lv's Avatar
I am much happier with the Autolites. Running AR93s right now.
Ed here clued me in on them Car run's much cleaner N/A with them then they did on the NGK's...and i have been running NGKs for years
Old 10-16-2006, 11:10 AM
regorih383's Avatar
whats the difference from the AR93s and the 104s
Old 10-16-2006, 06:56 PM
DroppedM6Z's Avatar
and i think ed is on Delco wires right?..lol cant beat that 513rw huh?
Old 10-16-2006, 09:00 PM
TwoFast4Lv's Avatar
AR93s are like heat range 9 in NGK
Quick Reply: 383 N/A Plugs
