Heads info needed
Old 10-17-2006, 06:58 PM
Long Beach's Avatar
Default Heads info needed
I just picked up a set of 853 heads hand ported with stock valves and 918 springs. Im going to run these with a 224/224 .564 112 cam or a 224/228 .563 112 cam. I want to know how much to mill these heads to get me close to a 10:9:1 compression using new stock head gaskets? Also if i mill these to get this compression what length pushrods do i need? I havent bought the gaskets so im open to sugestions. thanks
Old 10-17-2006, 08:50 PM
Long Beach's Avatar
anyone
Old 10-17-2006, 09:31 PM
ArrestMeRed99Z28's Avatar
what is your reason for using a stock sized head gasket? Using a thinner one from Cometic or whichever company you prefer will get you a better quench area and you'll have to cut the heads less which is good if you ever want to re sell them. Just my $.02
Good Luck
AJ
Old 10-17-2006, 10:24 PM
Long Beach's Avatar
Good Luck
AJ
Thats what im trying to find out. I have serched and could not find what im looking for. If i use one of those gaskets how much do i have to mill to get arround my desired compression? And if i do that what length pushrods will i have to use to work. thanks
Old 10-19-2006, 09:58 AM
Gunnar@Patriot's Avatar
If you use a cometic part #C5788-040, mill the heads approx. .018", you should end up with a compression of approx. 10.9-11.0.
Old 10-19-2006, 11:38 AM
muncie21's Avatar
Make sure the 853's don't have the infamous notch in them (mine do) if so you'll need to run composite gaskets to seal them.
Old 10-19-2006, 02:28 PM
cam1999's Avatar
What notch?
Old 10-19-2006, 04:54 PM
Long Beach's Avatar
Do you have these in stock, and these will work with the 853 heads. thanks
Old 10-19-2006, 04:55 PM
Long Beach's Avatar
Im not sure about the notch, please explain? Also what brand of gaskets are these composite gaskets?
Old 10-19-2006, 05:21 PM
Long Beach's Avatar
Also how much do i mill these using stock gaskets #12498543 to get arround a 11:0 compression? (The heads are not a big deal, so resale is not a concern) thanks
Old 10-19-2006, 06:43 PM
muncie21's Avatar
The info below was originally posted by SDPC (can't find the post now) but it tells you all you would want to know about 'the notch'.
BTW, my 853 heads from a 99 had the notch...and guess what..they leaked when I used MLS gaskets on them. Enjoy.
Old 10-19-2006, 07:13 PM
Long Beach's Avatar
Ok, yes mine have the notch you are talking about. If i just get some GM gaskets #12498543 this is the gaskets for the earlier year ls1's should work to seal that notch up right? What gaskets did you end up using then? thanks
Old 10-19-2006, 08:13 PM
muncie21's Avatar
The earlier head gaskets should have different part numbers for right/left side. They are composite gaskets, as apposed to MLS ones, also.
I ended up putting 317 (6.0L) heads on mine and used the 6.0L MLS gasket. Works great, no complaints.
Old 10-19-2006, 08:21 PM
Long Beach's Avatar
The reason im asking is i went to the dealership and they told me that i need part # GM part number 12498543. They said it comes in a set of two. They said this is the gaskets needed for years 1997-1999, the 2000-200+ use #GMPN 12498544. So should i just buy the first set, assuming that they are two different gaskets that i will need? thanks
Old 10-19-2006, 08:25 PM
muncie21's Avatar
Sounds like it's a kit. It should work, provided it's the composite gasket. Really easy to tell the difference.
Old 10-19-2006, 09:35 PM
Long Beach's Avatar
How can i tell if it is composite? It will not be stacked sheetmetal or what. thanks
Old 02-26-2012, 09:46 AM
Htown's Avatar
Default older heads on my 02 trans am Help
i recently got a set of 806 heads with a bunch of cnc work by slp got the flow numbers from them there pretty good anyways i put them on my car havent started it yet. im hearing the head gaskets are not compatable with older heads and its going to spew coolant is this true help. if it is what gaskets do i run
