Rear Brake question
Rear Brake question
On the rear brakes of our beloved LT1 F-body's, there's a weight of some sort hanging on the e-brake cable bracket. Ive heard of people having to grind these down some to clear aftermarket wheels and such...
But I have a slightly bigger problem, I narrowed my rear end enough that the LCA mounting point on the rear end is completely in the way of these weights going back on. I cant grind them down any, because it would literally require cutting the weight in half.
If I decide to remove my e-brake, can I also remove this bracket and weight without any adverse effects?
If not, can the weight be relocated without any adverse effects. I could cut the mounting stud off and weld it up higher on the bracket about 1 1/2" above and towards the wheel face at a 45* angle. (basically the angle the bracket follows, cut it down and weld the stud on the shorter bracket)
My mounting stud for the weight literally sits 1/8" away from the LCA bracket.
Do I have any other options to deal with this small dillema?
Thanks in advance
Thanks in advance
Yeah the ebrake is still their and worked when I took everything apart. I was just making sure their wouldnt be any adverse affects if I removed the weight.
Id like to keep the e-brake, but if it wont work without that silly weight thing, Ill gladly get rid of them or modify the bracket to hold the weight closer to the brake
I took my ebrake handle/ cable/ everything ebrake related off the rear breaks, and had no problems with stoping. I believe the weight needs to be there to use the ebrake, but servse no purpose if you not using the ebrake.
Ok, cool.
Tony do you still have your e-brake? Or did you remove everything associated with it as well?
The weight is mounted to a stationary bracket, nothing it attaches to moves. So what exactly would this weight do for the e-brake, thats not neccessary for the regular brakes?
Originally Posted by Fire67
Ok, cool.
