Good or Bad
Originally Posted by Ryan K
So, why do you think you have 3.73's? Are you compairing your tach to the speedo? Most tachs are a 1-200 rpm high when compaired to the Computer...
Ryan K.
Ryan K.
I figure that with 19,000rpm, and a 26" tire, you have right around 34.2 gears in that thing!! or at 1900 in 6th gear (figured at .54 OD which I think is the 6th gear ratio) you have 3.42's. Guess it could be different if you have a taller tire, eitehr way. here's the link I used. It would be real easy using your speed and rpm in 4th gear (that's 1:1) then there's no other figuring to do.
http://www.csgnetwork.com/gearratcalc.html
And if it were me, I'd prefer 3.42 (had 3.73 and just had to shift too quick).
Later,
Dave
Later,
Dave
