Good or Bad
Old Oct 24, 2006 | 11:51 AM
JD_Z28's Avatar
Default Good or Bad
We'll I just found out that my car has 3:73's and I wasn't sure if this is a good thing. With the mods in my sig would it be better for me to be running a taller gear? Right now i'm running the 60-1 but i'm gonna be running the a 70 trim.
Old Oct 25, 2006 | 12:13 PM
JD_Z28's Avatar
Bump.....
Old Oct 25, 2006 | 01:16 PM
Ed Blown Vert's Avatar
Are you sure? Your tune shows 3.42
Old Oct 25, 2006 | 01:29 PM
JD_Z28's Avatar
Pretty sure...My tune could be set for the wrong gears.
Old Oct 25, 2006 | 01:44 PM
True. Your speedo would be off.
Old Oct 25, 2006 | 02:23 PM
Ryan K's Avatar
Pathological Modifier
So, why do you think you have 3.73's? Are you compairing your tach to the speedo? Most tachs are a 1-200 rpm high when compaired to the Computer...
Ryan K.
Old Oct 25, 2006 | 02:26 PM
JD_Z28's Avatar
Ryan K.
The guy I bought the car off thinks their 3:73. If the spedo is correct and i'm at 19000 rpm's at 80mph would that indicate 3:42's or 3:73's?
Old Oct 25, 2006 | 02:37 PM
Turbo LS1 SS's Avatar
jack up the rear wheels and see how many times the wheel turns vs the driveshaft. problem solved
Old Oct 25, 2006 | 02:40 PM
SUPER DAVES Z's Avatar
I figure that with 19,000rpm, and a 26" tire, you have right around 34.2 gears in that thing!! or at 1900 in 6th gear (figured at .54 OD which I think is the 6th gear ratio) you have 3.42's. Guess it could be different if you have a taller tire, eitehr way. here's the link I used. It would be real easy using your speed and rpm in 4th gear (that's 1:1) then there's no other figuring to do.
http://www.csgnetwork.com/gearratcalc.html
And if it were me, I'd prefer 3.42 (had 3.73 and just had to shift too quick).
Later,
Dave
