01 engine is pulled!!!
install into the 98 will begin tonight!! so far everything is going good. no major mishaps or anything.
my old 98 engine
the engine coming out the 01
put new springs in
painted the fuel rails and dipstick
my old 98 engine
put new springs in
Since you have the 98 motor in front you, can you see if the tempature sending unit has the same type of plug as the 01? Apparently the 98's actually give you a degree, andd are better than the 99-02's. The 99-02's apparently were only a hot/cold sort of measurment. But I was wondering if the 98 had a differnet connector on it.
Originally Posted by Sneakyws6
You did not take that out through the top did you? I thought the LT1/LS1 motors had to come out the bottom.
you can see in the shot where he says the motor coming out of the other car that it's coming out the bottom and is still attached to the subframe. Unless you remove(cut out) the core support it has to go out below. Another fine GM idea!!
well the engine is "in". all that is left is hooking up the wires, we still need to put the new fuel pump in, then hopefully it will start. everything was a direct bolt in except for the oil pressure and water temp sending units. i will post some pics in the morning but right now i am too tired the only problem so far is the steering rack is leaking where the steering rod goes on. we do not know why.
Ben T.
Originally Posted by Long Beach
Where at in montana are you located?
we live in eureka, mt. but you probably wouldn't even be able to find it on a map its in the northwest corner and we are about 10 miles from the canadian border
everything went very well tonight. we ended up switching out my power steering rack with the 01s. that actually went very smoothly thankfully. the engine is now fully installed and the wiring is all hooked up. tomorrow will be a full days worth, we have to pull the gas tank and install the new fuel pump. we still need to put in the driveline, hook up the exhaust, and several other misc. things. hopefully by tomorrow night i will be able to post that it is running!!!
Originally Posted by staringback05
^^^ i believe so....its just funny how many people dont believe that one ls1 block can be sloppy and the next right off the line can be really tight
Originally Posted by 99camarosupersport
How hard is dropping the engine out of a car w/out a lift? or is it even possible?
What is the reasoning for changing engines? if you don't mind me asking. Hopefully you haven't already said and i just missed it.
