01 engine is pulled!!!
Old Oct 25, 2006 | 09:10 AM
beautie's Avatar
Default 01 engine is pulled!!!
install into the 98 will begin tonight!! so far everything is going good. no major mishaps or anything.
my old 98 engine
the engine coming out the 01
put new springs in
painted the fuel rails and dipstick
Old Oct 25, 2006 | 09:19 AM
Sneakyws6's Avatar
On the tree
You did not take that out through the top did you? I thought the LT1/LS1 motors had to come out the bottom.
Old Oct 25, 2006 | 09:26 AM
WS6FTW's Avatar
Since you have the 98 motor in front you, can you see if the tempature sending unit has the same type of plug as the 01? Apparently the 98's actually give you a degree, andd are better than the 99-02's. The 99-02's apparently were only a hot/cold sort of measurment. But I was wondering if the 98 had a differnet connector on it.
Old Oct 25, 2006 | 09:42 AM
bygblok's Avatar
you can see in the shot where he says the motor coming out of the other car that it's coming out the bottom and is still attached to the subframe. Unless you remove(cut out) the core support it has to go out below. Another fine GM idea!!
Old Oct 26, 2006 | 12:31 AM
beautie's Avatar
well the engine is "in". all that is left is hooking up the wires, we still need to put the new fuel pump in, then hopefully it will start. everything was a direct bolt in except for the oil pressure and water temp sending units. i will post some pics in the morning but right now i am too tired the only problem so far is the steering rack is leaking where the steering rod goes on. we do not know why.
Old Oct 26, 2006 | 12:32 AM
1LoudTA's Avatar
i took mine out the top, you just have to pull the accessories, the intake/fuel rail setup.
1LoudTA's Avatar
and radiator/condensor
Old Oct 26, 2006 | 12:35 AM
Studytime's Avatar
Just the sensor won't make it function any better than an idiot light if you have a '99+ LS1 car.
Ben T.
Old Oct 26, 2006 | 02:03 AM
Long Beach's Avatar
Where at in montana are you located?
Old Oct 26, 2006 | 02:18 AM
staringback05's Avatar
i have a 01 in my 99...and i know everyones going to jump on me at this....but its a world of difference...that 99 motor was so loose...good luck
Old Oct 26, 2006 | 02:34 AM
99camarosupersport's Avatar
perhaps you had a dog of a 99 and a factory freak 01?
Old Oct 26, 2006 | 02:38 AM
^^^ i believe so....its just funny how many people dont believe that one ls1 block can be sloppy and the next right off the line can be really tight
Old Oct 26, 2006 | 08:09 AM
beautie's Avatar
we live in eureka, mt. but you probably wouldn't even be able to find it on a map its in the northwest corner and we are about 10 miles from the canadian border
Old Oct 26, 2006 | 09:15 AM
beautie's Avatar
my new exhaust
close up of my new engine with painted coil packs, fuel rail, and dipstick
engine going in!!!
Old Oct 26, 2006 | 11:19 AM
How hard is dropping the engine out of a car w/out a lift? or is it even possible?
Old Oct 27, 2006 | 01:22 AM
beautie's Avatar
everything went very well tonight. we ended up switching out my power steering rack with the 01s. that actually went very smoothly thankfully. the engine is now fully installed and the wiring is all hooked up. tomorrow will be a full days worth, we have to pull the gas tank and install the new fuel pump. we still need to put in the driveline, hook up the exhaust, and several other misc. things. hopefully by tomorrow night i will be able to post that it is running!!!
Old Oct 27, 2006 | 01:23 AM
Long Beach's Avatar
Yes i know where it is i grew up in hardin. Good to see some fellow ls1 owners on here from big sky country.
Old Oct 27, 2006 | 01:25 AM
beautie's Avatar
This engine put down 501 rwhp & 569 rwtq through a 9" on a mustang dyno with a 100 shot. We never dyno'd it NA.
Old Oct 27, 2006 | 01:08 PM
01Z28MN6's Avatar
from what i know it isn't possible you have to get the front of the car up and over the engine, unless you have a really tall jack.
What is the reasoning for changing engines? if you don't mind me asking. Hopefully you haven't already said and i just missed it.
Old Oct 27, 2006 | 01:46 PM
1sick'98WS6's Avatar
you did new motor mounts while you had it out... right?
