Why power peaked at 5,700 w/FM-13
Well I am looking a little more into the reason my car peaked so quick on the dyno.
I was thinking it was because of the LS1 intake starving a bit for air .
Also a few times at the top of the RPM range I get a p0103 MAF high frequncy . I will be changing the MAF tommaorw and the the connection seems good .A few people had mentioned that it may be a tooth off . I am very attenteive when I do this so I am don't think it is off but maybey my eyes weren't working right that day .
Any ideas or is it normal
Mod list is
01 Heads Ti retaners Duel springs hardend rods
FM-13 cam
SLP LT
LS6 ported oil pump
LS2 chain
SLP lid
180 t-stat
Thats it
Mod list is
FM-13 cam
SLP LT
LS6 ported oil pump
LS2 chain
SLP lid
180 t-stat
Thats it
Originally Posted by black_z
I disagree, plenty of people peak higher than that with an F13 and just about every other cam. I think the intake is whats holding you back, what LSA and ICL for the FM13?
With your mods, you're not pulling enough air to cause high MAF error, so that is an issue. Is it clean? You don't show the A/F on the graph, were timing and A/F optimized while it was on the dyno? Do you have cats? was COT turned off?
The torque curve is very flat and wide. SLP L-T contribute a bit to that and possibly the cam has too much advance.
has the car been tuned? I have an f13 on 111lsa+1. It peaked at around 6300-6400 and pulls hard to 6800. It made 396/372. But i do have the LS6 intake. other mods were Lt's, borla cat back, Lid, Tuned. I think yours should be peaking atleast as high as mine unless it was ground on a real low lsa which i doubt.
