806 heads to 241 heads
Old 10-26-2006, 10:39 AM
GR33N GoblinM6's Avatar
Default 806 heads to 241 heads
98 camaro M6
currently has 806 heads on it... i got some 241 bare heads for basically nothing. looks like there was some mild clean up work done to them on the bowls and runners.
Would I be gaining any HP at all by just swaping heads? I know I would gain more with a port job (which I might do considering they are bare right now). I just wanted to know if there were any gains at all going from these heads to the 241's.
Also, would there be a benifit by going with bigger valves?
Old 10-26-2006, 10:57 AM
Studytime's Avatar
There would be maybe a 5hp difference if you just slapped them on your car. Also, your 1998 valves aren't as good as the later valves. So, that there might be a reason go to bigger or atleast try and get a set of valves out of a 853/241 head.
Bigger valves could show more flow, but unless they're ported it may not be worth it. You'll also give up some PTV clearance with the bigger valves in them.
If you could get a good valve job on them, some really light port work, and have them decked you could probably see another 25hp or so out of them.
Ben T.
Old 10-26-2006, 12:28 PM
JZ'sTA's Avatar
So little it would be a waste of time to swap heads.
Also the valve cover is different from the 806 castings to the 241's so you will spend additional money to convert the 2001+ 241 head on your 98 F body.
Old 10-26-2006, 01:28 PM
Already have the center bolt valve covers.. with bolts and brackets for coils.. already have compcam springs good to .580 lift.. have new valve seals from ThunderRacing, New valve locks as well.
Ive held off on getting pushrods until i know what length I will need, if I have the heads worked or milled.
What size valves could I go to? 2.02 intake & 1.60 exhaust or 1.55?
I have not decided on what cam to use. I have been looking at the FMS 224/224 114 cam.. also the LS6 HOT Cam, and TSP & SDPC cams..
Goal of the car is not a drag car.. but more of a road racing, canyon carving type. But I dont want something too radical, but have relatively mild street manners.
I know there are plenty of heads out there that will flow more than these, but Im sticking with these since they were basically free, and better than what I have. Plus im not looking to MAX out my engine on HP.. just some extra for spirited drives in the mountains and an Larry H. Miller race track in UT.
Old 10-26-2006, 02:14 PM
JZ'sTA's Avatar
Personially I still don't think it's worth the swap unless you get them ported and milled.
The 224 can you said should work fine, and the spring's won't mant a much bigger cam then that anyway.
As much work/money it is to swap the heads and cam I would wait some time and get you combo exact the first time, that way your happy and not wanting to change the combo in a couple months.
I personially would port those heads and get a good spring kit for the heads. Then do a good all around cam like a 224/228 cam and get some great mid range while still having some impressive top end.
Old 10-26-2006, 02:44 PM
good,... ill get them worked over then.
what about valve size?
Old 10-26-2006, 06:42 PM
Studytime's Avatar
It would probably be hard to go wrong with 2.02 & 1.57" valves.
Ben T.
Old 10-26-2006, 06:44 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Keep your stock sized valves. Get them done up right then install the 241's. I did the same thing except from a 99' 853 casting.
Old 10-26-2006, 10:05 PM
8GTOKLR's Avatar
241 Heads 64cc 2.02 1.57 stainless
i split the difference between 224/224 and the hot cam and went with Vinci boss 216/224 .551 , used stock length hardened pushrods, and added some rhoads lifters to give some stealth
Old 10-27-2006, 02:36 PM
thanks guys
Old 10-28-2006, 07:39 AM
GuitsBoy's Avatar
post some pics and we can see how much cleaning up has been done... I picked up a good bit of power with a fairly mild cleanup.
