safer at high rpms?
Old 10-27-2006, 11:25 PM
da boss's Avatar
Default safer at high rpms?
I am trying to find out want needs to be done so that the engine can be safely and reliably run up to about 7k rpm. I am rebuilding my old engine and the plan so far is to do a trex cam, new valve springs, ARP rod bolts, ARP head bolts, hardened push rods, new spark plugs, bigger injectors and fuel pump, and some tuning. Is their anything else I need to add that will make this engine more effective and more reliable at higher rpm. Thanks ahead of time for any responces I get.
Old 10-28-2006, 03:12 PM
da boss's Avatar
no one is going to respond wow.
Old 10-28-2006, 03:17 PM
mooreperformance's Avatar
titanium retainers and I think your set.
Old 10-28-2006, 03:21 PM
Project GatTagO's Avatar
Received 1,394 Likes on 880 Posts
I would also upgrade the connecting rods.
Andrew
Old 10-28-2006, 03:24 PM
sickss228's Avatar
No need to upgrade the connecting rods, the weakest part of any rod is the fasteners, just go with ARP rod bolts, a good spring like comp 921's. ti-retainers, hardened pushrods and maybe a set of good lifters since you'll have the motor apart anyway.
Old 10-28-2006, 10:39 PM
Everyone has an opinion:
http://www.torquecentral.com/showthread.php?t=39232
Andrew
Old 10-28-2006, 11:18 PM
Thimble's Avatar
"Stock rod bolts don't like the occassional 8krpm and constant 7200rpm"
How long did it survive that abuse?
Old 10-28-2006, 11:53 PM
1999 SS's Avatar
lighter valves
Old 10-29-2006, 12:03 AM
cam
cam's Avatar
lighter valves
Save your money on the ti retainers and put the dollars into the valves. You save a few grams on the retainers but a good amount on the valves. Search Katech posts. You'll find all the info you need.
Stock valves 6400 RPM max or your risking it.
Old 10-29-2006, 08:29 AM
I think he has been beating on that car for about a year now. I understand that this abuse is a little extreme, but the cost of a decent set of rods is very reasonable these days. To me it just makes sense to upgrade them while your doing a complete rebuild.
Andrew
