LS1 induction on LT1 Z
Old 10-31-2006, 07:16 PM
JUICED96Z
Guest
Posts: n/a
Default LS1 induction on LT1 Z
Can you make a LS1 induction system work on a LT1 Z with the factory hood?
IE if you do some grinding and cutting will it work or do you need a ram air or cowl hood?
Old 10-31-2006, 07:32 PM
UA-Plumber's Avatar
Search It. Most say youll need an aftermarket hood. PM "The Merv" He is/did put one on his.
Old 10-31-2006, 08:12 PM
jimbob's Avatar
Like this [IMG]
Attached Thumbnails LS1 induction on LT1 Z-img_3499-1.jpg   LS1 induction on LT1 Z-img_3501-1.jpg
Old 10-31-2006, 08:29 PM
UA-Plumber's Avatar
They do exist! Did you make that radiator shroud yourself? It looks good.
Old 10-31-2006, 08:33 PM
TwoFast4Lv's Avatar
Yup Jim did it all in the shop. Did not really take him that long
Old 10-31-2006, 08:49 PM
UA-Plumber's Avatar
I might look into that. Thanks for the proof.
Bryan
Old 10-31-2006, 09:39 PM
daniel6718's Avatar
how come i had to cut all the4 webbing out of my hood, then my radiator support, and lower it about 2 inches to get mine to work?
Old 10-31-2006, 09:46 PM
daniel6718's Avatar
nvm, how is the filter helt in???
and where is the MAF? because mine sticks way further foroward...prolly why i had to cut the hood almost the latch and the reason the radiator support had to be cut....
Old 10-31-2006, 09:49 PM
borninatransam's Avatar
can we get pics with the lid and filter off? i could fab this up pretty easily it looks like i just need to see the rest of the radiator shroud.
Old 10-31-2006, 10:17 PM
streetwarrior96's Avatar
Old 11-01-2006, 01:11 AM
JUICED96Z
Guest
Posts: n/a
Not a Z hood ^^^
Old 11-01-2006, 01:41 AM
onebadblackz's Avatar
The_merv has one mabye he will post up some pics....
Old 11-01-2006, 09:10 AM
nemanracing's Avatar
He had to cut his stock hood to make it fit...
Old 11-01-2006, 09:16 AM
TwoFast4Lv's Avatar
Jim Layed the Radiator back and we built new Radiator holders. We will have to get some more pic's. He also made a thin cover that holds the filter up and makes it look nicer
BTW he is using a 85MM MAF. if you look close enough you will see the wires on the driver side
Old 11-01-2006, 09:20 AM
the_merv's Avatar
Yea, I had to cut the stock Hood, there was no way it was going to fit under it, without some major cutting somewhere. Someone said that they got it in without any cutting on a stock Z28, and I called Bull ****..
A friend has a Cowl that we are goin to see if it will fit on it, that's what will be needed to cover it up. I got it to look semi-decent the way it currently is. People look at it, and are like that thing isn't factory. I have to cover it up, so that way it's not too obvious.
Old 11-01-2006, 01:59 PM
lt1_man's Avatar
I have seen a few people with the ls1 style intake with out cutting the stock hood. They had to do some modifications to the mounting of the intake but it worked. I think I saw that on here.
-Brandon
Old 11-01-2006, 02:08 PM
ToxicFormula's Avatar
it does look good though, it looks really clean
Old 11-01-2006, 02:46 PM
blkchevyz's Avatar
really?
Old 11-01-2006, 02:50 PM
Originally Posted by blkchevyz
really?
I like it cause it adds a lil spice to the boring lt1 hoods. and its not a hackjob with really rough edges and cockeyed lines, it was done really really well IMO
Old 11-01-2006, 02:53 PM
LT4POWR's Avatar
Quick Reply: LS1 induction on LT1 Z
