LS1 induction on LT1 Z
and where is the MAF? because mine sticks way further foroward...prolly why i had to cut the hood almost the latch and the reason the radiator support had to be cut....
BTW he is using a 85MM MAF. if you look close enough you will see the wires on the driver side
A friend has a Cowl that we are goin to see if it will fit on it, that's what will be needed to cover it up. I got it to look semi-decent the way it currently is. People look at it, and are like that thing isn't factory. I have to cover it up, so that way it's not too obvious.
-Brandon
[IMG]
