my sts install pics
Old 11-03-2006, 11:51 AM
RooRnZ28's Avatar
Default my sts install pics
check out the cardomain link below for more pics
Old 11-03-2006, 09:53 PM
OUTLAWZ RACING's Avatar
Did you by that cam from Billy?
Old 11-04-2006, 05:16 AM
RooRnZ28's Avatar
yes i did.... ran great before turbo
Old 11-04-2006, 07:44 AM
NYSS Guy's Avatar
So you're driving the car without a tune??? Better keep a close eye on the boost. What kind of fuel system are you running?
Old 11-04-2006, 02:19 PM
RooRnZ28's Avatar
i am running 1 walbro in tank w/ BAP and 60# injectors, but the injectors arent in yet. i have only driven her home, and it's just been sitting in the garage till i can get my tune. anyone know any tuners in cali?
Old 11-04-2006, 04:16 PM
SleeperZzZ28's Avatar
go here and ask these guys or there is a guy named Tondss on this board... I think he changed his name to Mr. President or something though.
http://www.fresnoracing.ipbhost.com/
Old 11-04-2006, 06:59 PM
Schantin's Avatar
Looks nice. I see you wrapped the STS pipe going by the headers. I had to do the same.
Definetly get the car tuned before getting crazy on it. Sure you already know that one.
If you cut the mounting tab for the filter off your K&N FIPK II radiator shroud, it makes a nice STS radiator cover. Here's a pic of mine.
Shortening the upper radiator hose by approx 1" right as it enters the radiator will keep it from hitting the STS intake pipe. This prevents you from having to use zip ties or similar to keep the pipe away from the power steering pully.
Overall......looks nice.
Old 11-26-2006, 03:14 AM
RooRnZ28's Avatar
more pics up
Old 11-26-2006, 10:19 AM
Blackbird's Avatar
go to Synergy for the tune.
www.synergymotorsports.net
Old 11-26-2006, 10:22 AM
XpEdItIoUs's Avatar
Quick question, Is alot of people getting this kit beacause it's affordable or can you pass smog with it?
Old 11-26-2006, 03:05 PM
dementia's Avatar
It passes smog, its got an entry level price tag, and people are making some decent numbers with it.
Old 11-26-2006, 04:27 PM
jv_Z28's Avatar
Synergy Motorsports (510)796-3749
Old 11-26-2006, 04:55 PM
RooRnZ28's Avatar
i mainly wanted to keep my ac.... the car is my daily driver. yes it is cheaper than other kits, but its amazing how things add up! now passing smog is a different story....
well i called them about 2 weeks ago to set an appointment up, but they never returned my call..... not impressed so far, any others?
Old 11-26-2006, 06:11 PM
Coy
Coy's Avatar
What is the ground clearance at the lowest point on your car, because it looks VERY low under the K-member.
Old 11-26-2006, 06:38 PM
Blackbird's Avatar
Thats suprising they didn't call you back. I would call them again and ask for Rick directly. He will make sure your taken care of.
Old 11-26-2006, 09:20 PM
GR33N GoblinM6's Avatar
wrong.. it does NOT pass ALL smog laws in CA, which is where the poster is from.. OC CA... it does not have an EO# (executive order # from C.A.R.B.)
Old 11-27-2006, 09:19 AM
Blackbird's Avatar
correct.
but if you pull the pipe that connects to the tb and put your stock airbox back on, as long as your tune is good you will pass no problem.
I just did this 3 weeks ago at a test only station. It's all post cat at that point so there is nothing they can say.
Quick Reply: my sts install pics
