Thermostat
Thermostat
How do i know if my thermostat is gone or the previous owner had put it a low temp stat . The car runs on the highway at just below the quarter mark and when im in city it climbs to half is. it normal ?
Well first of all there is no way that ur thermo is gone, second of all just look at the temp needle..................... I know they arent terribly accurate but just a general idea will tell you if its the stock ( 200ish) or the aftermarket(160ish)
LS1Tech Administrator
Received 1,795 Likes
'99+ cars will always show "210" unless the motor is still very cold or it's seriously overheating.
Originally Posted by RPM WS6
Is your car a '98? If so those readings sound about right for the stock t-stat. That's the only year that will register minor changes in temp on the temp gage.
Originally Posted by Zymosis
With my 160* T-Stat it shows maybe 1/8th inch under 210* in fully warm position.
my 98 wont touch the 1/4 mark on the gauge unless im sitting idling, otherwise its barely above 160.
Originally Posted by bww3588
yours will ALWAYS read that no matter what thermostat you have in it. your temp gauge is a dummy gauge. it only works if it overheats.
