Drag Racing Tech
Master Flo gauge
Old 11-06-2006, 10:49 PM
next's Avatar
Default Master Flo gauge
Well I can't help but to share my new toy. I picked up a Master Flo Check Pro gauge from Nitro Dave and this is a thing of beauty. Beautiful BIG 6" read out. Them some tiny little increments for measuring psi there
Great NX piece!
Old 11-07-2006, 12:09 AM
94z28L's Avatar
oooh pretty!
Old 11-07-2006, 07:54 AM
The Bull
DERTY's Avatar
I used one and it definitely is bad ***. Word of caution, make sure that it is straight up and down when you use it. The gauge is so heavy that gravity does some magical things to the readings. Just make sure that you hold it the same way each and every time you use it. Also, make sure that keep the reference line straight and bleed the air out before taking your reading. If you do that you're readings will be spot on every time.
Old 11-07-2006, 07:58 AM
next's Avatar
Thanks Derty. I noticed when I first looked at the gauge lying flat in it's case it wasn't reading 0. Then I held it upright and realized what you are talking about.
Old 11-07-2006, 10:59 AM
8 Sec Tuner
Mike TexaSS's Avatar
It's also important to hold the gauge level with the solenoids when flowing your system. Like Derty said, gravity will affect your reading.
-Ben R
Old 11-07-2006, 11:13 AM
next's Avatar
Ben - I wouldn't have known that had the instructions not directed me accordingly. I guess it pays to read those things
Old 11-07-2006, 11:59 AM
8 Sec Tuner
LOL, I never read those things either!!
Old 11-07-2006, 01:31 PM
1QuickT-A's Avatar
how much???
Old 11-07-2006, 01:56 PM
8 Sec Tuner
$280ish if I remember correctly.
-Ben R
Old 11-07-2006, 02:24 PM
next's Avatar
Like said above -
http://www.nitrousoutlet.com/catalog...el=108&dept=11
Old 11-07-2006, 04:44 PM
7 Second Club / STF Veteran
68maro's Avatar
basically put it level with the solenoids and hold the gauge so it zeroes out the needle it's what i use and it reads the same as some of my buddies really expensive ones that they calibrate with the zero out ****.
Old 11-07-2006, 08:51 PM
N20Silverado's Avatar
Wait untill you use it and compare it to the guage on the car. The guage on my buddy's car was over 1 psi off. WOW were we surprised. That's huge on a 400 shot.
Tim
