New tranny & converter, but ran 2-3 tenths SLOWER! Which is the culprit..
Old 11-12-2006, 12:59 PM
YO-EL's Avatar
Default New tranny & converter, but ran 2-3 tenths SLOWER! Which is the culprit..
HAD a 3200 stall, put in a 3600, but my 60' went UP from low to mid 1.5's to mid-upper 1.6's... Translates into .2 in ET...
Ridiculous...
Before the swap & ran low -mid 11's..
Friday night & yesterday, I was running 11.70's-11.80's...
My car NEVER even saw 11.60's, on the hottest 95 degree day & 4000DA..
Anyway, I'm sensing its the converter...
Just no hit, no matter what the launch, feels like its pushing thru, not holding any pressure..
Tranny seems like its shifting fine...
Am I on target focusing on the converter, I mean, can it be not stalled properly or not have the right STR out of the box...
$$$ is at stake as I'm gonna have to pay labor AGAIN to drop the tranny etc..
What do you think, tranny or converter
Old 11-12-2006, 01:48 PM
LS1Tech Sponsor
performabuilt's Avatar
Likely a converter issue , transmissions simply transfer power ,though there shift elapse from gear to gear can have and effect but assuming The transmission shifts are solid that would be my guess
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 11-12-2006, 02:39 PM
Yank's Avatar
I have seen many a transmission cause this can be a crossleak in valvebody or even the front pump allowing the converter clutch to apply even when not commanded to do so by the PCM
also very high line takes horsepower away from the engine this can cause an internal leak as stated above what is your line at WOT.
if the converter has a higher stall it will feel stronger in the 60' range you are stating 3200 to 3600, what are you seeing in stall or flash rpm.
You did not state you MPH #
Old 11-12-2006, 02:54 PM
YO-EL's Avatar
MPH speeds are off 4-5 mph..
Usually trap 119-120, Fri & Sat trapped 115..
Line pressure & ALL transmission parameters are stock settings..
Is there any way to test or check the converter while its still installed in the car
Really is a dog off the line.. There's no hit at all...
60' times are slower by a tenth- 1.5 tenths
Old 11-13-2006, 04:42 PM
01_ram-air's Avatar
Hmmm, I'm also wondering if this could be a tuning issue also going from the 3200-3600 stall. What converter did you go from---to? Same brand?
Old 11-13-2006, 06:27 PM
YO-EL's Avatar
Same brand, and found out they're BOTH the same part #..
So it ended up being an exact replacement..
Been thru this a few yrs back, ended up being the converter..
I just can't believe I'm having to do this 2 converter swap in & out & in & out all over again....
Old 11-14-2006, 08:54 AM
Yank's Avatar
If it is the same converter part # then I would look at the transmission.
Old 11-19-2006, 07:13 AM
YO-EL's Avatar
We found out that the bolt on the clamp on the transmission drive shaft had come loose, so at high rpms, it was slipping...
Tightened, & ran normal ET's & 60's...
This is @ the front of the car, behind the oil pan, remove a horizontal oval shaped rubber gromet & the bolt is up there.
Never heard any noise or clanking, but as soon as the rubber cap was removed, the bolt fell out..~!
Old 11-19-2006, 08:16 AM
FLT
FLT's Avatar
So a faulty installation. Am I correct? Or was it never touched and was probably the problem before the swap? Vince
Old 11-19-2006, 09:22 AM
Yank's Avatar
That is good info! as I have not heard of that before
but you might check as
the shaft is heat treated steel and the internal spline is cast iron so the splines might have rounded the tops off.
Old 11-19-2006, 11:51 AM
YO-EL's Avatar
I'm not sure where to go with it, as to who's fault, where or when, but this is something everyone reading should check for tightness..
The splines are fine.. If not, I'd be slipping on launch...
My 60' times went from an abnormal 1.65+ down to 1.57 consistently once it was tightened & my ET's went from last Saturdays abnormal 11.70's to 11.36 yesterday.. Same DA +400.
