Anyone have a proven PCV system
Old 11-13-2006, 03:43 PM
7 Second Club
Phil99vette's Avatar
Default Anyone have a proven PCV system
PCV systems seem to be never ending, has anyone made a system that elminates the oil in the intake problem?
Phil
Old 11-13-2006, 04:00 PM
dug
dug's Avatar
Whats the drawback of junking the pcv and going with a breather?
Old 11-13-2006, 07:10 PM
N4cer's Avatar
Excessive moisture in the oil.
I'm running an air/water separator that works well, but it's from Lowe's, and the bottom of it doesn't totally seal. I need to find a GOOD one, like off a hospital ventilator.
Old 11-13-2006, 07:30 PM
pdd
pdd's Avatar
Phil
that would be nice
Old 11-13-2006, 07:35 PM
2 SSlow's Avatar
well, if you go with a breather, all that oil that was going in you intake will now go in your breather, and eventaully blow a film of oil out under your hood. That is unless you clean it regularly...
I think i am going to try that 75$ catch can that is floating around in one of these threads...
Old 11-13-2006, 07:42 PM
Nate_Taufer's Avatar
No PCV is good PCV! I have no problems with my setup.
Old 11-13-2006, 08:18 PM
John02SS's Avatar
I've deleted mine as of yesterday. I have a LS6 valley, AMW catch can, and a Metco and still get oil in the intake. New setup has the valve covers connected, LS6 valley connected to the valve cover where the fresh air line was, and a metco on the passenger side. I'll beat on it this weekend and see how it does.
Old 11-13-2006, 08:34 PM
WKMCD's Avatar
Phil,
THe PCV system on my is not bad. The little in-line fuel filters (indicators) haven't been cleaned since I put them on. They've got about 4k on them now. If there was any oil in the FAST it was probably there from before this setup.
Kevin
Old 11-13-2006, 10:58 PM
Irocss85's Avatar
whats your setup then?
Old 11-14-2006, 12:55 AM
hammertime's Avatar
So, 2001+ LS1's do NOT get the LS6 valley cover with the LS6 manifold? I was about to create a threadfor this question.
Old 11-14-2006, 12:58 AM
ls1408cp's Avatar
Old 11-14-2006, 07:38 AM
JoeyGC5's Avatar
Originally Posted by ls1408cp
Showoff, If only us vette guys could be so lucky
Phil I've tried every possible combination, except use of the vacuum pump. Did you vac pump setup not turn out well?
Old 11-14-2006, 09:02 AM
AppleMac's Avatar
Everything capped and breathers on the valve covers works great...
Old 11-14-2006, 09:21 AM
7 Second Club
My vac setup works well, looking for solutions for cars without vac pumps.
Old 11-14-2006, 09:33 AM
stdjsw311's Avatar
damn thats sexy
Old 11-14-2006, 10:06 AM
STRIPSTAR's Avatar
I driven 4-5k miles with the breather and connected valave covers with no problem. People speak of oil film but i dont see any. my car drank oil before.
Old 11-14-2006, 02:31 PM
ls1408cp's Avatar
I just took of my intake and found oil. I think it is from rocker bolts or decel. I dont think you can win the oil in the intake thing.
Old 11-14-2006, 03:39 PM
Beast96Z's Avatar
Probablly reversion.
Old 11-14-2006, 03:44 PM
LS1Tech Sponsor
Slowhawk's Avatar
Phil
Breathers on the motor,ditch the PCV
Old 11-14-2006, 03:49 PM
9 Second Club NA
Dragaholic's Avatar
ls1408cp, to use a setup like yours, I'd guess you would either need to have a sheet metal intake or carb style intake like yours in order to have room.
Quick Reply: Anyone have a proven PCV system
