Drag Racing Tech
Can't keep the front end down on launch
Old 11-15-2006, 09:17 PM
LS1TECH Sponsor
Steve Burger's Avatar
Default Can't keep the front end down on launch
Neve thought I would have this problem but here goes.
Car is about 3350 race weight. QA1s all around, Full BMR suspension, LCA in the middle hole, 300 lb springs in front, stock springs in rear, TH350 TB.
When I launch off the TB the front end comes up about 2-3 feet. I have tried to set all of the shocks stiff (10+) and have had up to 23 lbs of air in the 28" ET drags. Still comes up a lot.
It looks cool but is costing ET.
What can I do?
Old 11-15-2006, 09:43 PM
LS1Tech Sponsor
Brady's Avatar
travel limiters. MadMan/Thunder Racing can hook you up!
__________________
1966 Chevy II twin turbo LS3 project
2016 Z07 Carbon
Old 11-16-2006, 12:35 AM
94z28L's Avatar
trade me cars lol
Old 11-16-2006, 07:15 AM
cwaldt's Avatar
Originally Posted by 94z28L
trade me cars lol
Good answer.
Old 11-16-2006, 08:55 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
I saw a few of your launches, it's a nice problem to have. Basically all you can do right now is travel limiters because you already tried stiffening up the shocks and putting more air in the slicks.
Old 11-16-2006, 09:19 AM
TeEnAgE pHeNoM's Avatar
Dang I wish I had an automatic? You can't beat one thats for sure?
Old 11-16-2006, 09:40 AM
kp
kp's Avatar
Sure those front shocks are working, on '10' my car just spins the tires and doesnt move. I usually crank the shocks full stiff when I tow the car, look at the 1/8 mile vid in my sig - thats what happens when I forget to loosen them on the first pass
But travel limiters or maybe try the LCAs in the stock hole if your car sits up high.
Old 11-16-2006, 09:46 AM
Old Geezer's Avatar
Soften the converter "hit".
Old 11-16-2006, 10:05 AM
Shon Herron's Avatar
Different ways. adding weight to the nose, pulling some timing to reduce the amt of TQ being produced, or change the exhaust so it produces less TQ, and getting the TC softened some might work.
The only thing I like about any of those options is the tuning and possibly the exhaust.
Have you tried lower RPMs on the TB?!
Old 11-16-2006, 10:10 AM
kp
kp's Avatar
I just assume people are using a 2 step and have tried different RPM launches but you are right. You can play around with the two step RPM and keep the car down as well most of the time.
Old 11-16-2006, 10:13 AM
I got to assume that footbraking the car you do not have this problem, that is why I would try a lower RPM on the TB.
If you are bracket racing then you will learn quickly how much this affects the 60' and then know how to adjust the dial in, considering all of the other factors, LOL.
Old 11-16-2006, 11:03 AM
LS1Tech Premium Sponsor
BMR Suspension's Avatar
Travel limiters are the best route....
Lee Spicher
lee@bmrfabrication.com
(813)986-9302
Old 11-16-2006, 12:43 PM
Retired Street Racer
Matt D's Avatar
I agree on the travel limiters. Jugger had really good luck with them. They are decently priced too if you go with Madman's.
http://thunderracing.com/catalog/?ac...id=166&sid=751
Old 11-16-2006, 12:48 PM
redneck01's Avatar
if travel limiters dont work...thats what wheelie bars are for. sucks on a street car but maybe the only way.
Old 11-16-2006, 12:58 PM
Resident Racing Jerk
vtec's Avatar
Travel limiters.
Old 11-16-2006, 03:35 PM
LS1Tech Co-Founder
Steve you have a 2step? You should email Jugger and get his thoughts.
Old 11-16-2006, 04:33 PM
raceme9s's Avatar
Travel limiters is what u need, wolferacecraft sales them for like $45
Old 11-16-2006, 08:40 PM
sbcgenII's Avatar
Dont sacrafice the launch with lower rpm or a softer hit just put the limiters on or try moving allitle weight from somplace else on the car to the front.
Old 11-16-2006, 08:56 PM
Hrod382's Avatar
Yeah, I highly recommend everyone playing with their 2 step RPM's. I launched mine at 3800 when I was first learning my car then when I turned it up to 4600 my car actually lost some in the '60, it picked the wheels up higher but when I leave at 3800 it picks them up 1-2 feet and holds them there for ~45 feet. My best 60 at 4600 was a 1.309, best at 3800 is 1.259. The car loves coming up on the converter and I get less height and but more time in the air. Cheap and easy way but everyones car is different and you may have tried this already.
Old 11-16-2006, 09:41 PM
1998TA__1991RS's Avatar
ive never really understood how a 2step worked, and i cant find a good thread on it, could someone please explain??
Quick Reply: Can't keep the front end down on launch
