traction light at 100mph ?
so i was on the highway on the way home. I was racing a 00z28. thats besides the point. I did a pull in 3rd gear from about 3 grand all the way up to 6k. btw is that bad becasue it was in the soft redline thing. after i get to 6k and let off the low trac light come on? any reason for this. there is nooooo way i could have broken the tires loose at that speed going in 2 4th is there.
well i do have shitty tires it was kinda wet. Idk maybe it just did not seem at the time like it was possibal. The first thing i thought of was ok somthing is deff wrong there is no way
I believe that it takes a physical difference of 11 MPH to trigger the traction control. However, you can have more timing problems at those higher speeds. The computer has trouble with detecting the raising and falling parts of the signal at those speeds when there is a large diameter difference.
Tech Resident
i can break the tires loose in 3rd gear going 35 mph if i rev it real quick to ~3 grand with the traction control on if the road is wet enough. what chance do you think you have a 6,000 rpm's?
