How much time to install heads???
Old 11-20-2006, 11:39 AM
pennys58's Avatar
Default How much time to install heads???
What is an average time needed to install fully assembled heads on the LS1? Shops are quoting me 10-12 hours, sounds a little high from what I have been told.
Old 11-20-2006, 12:18 PM
Long Beach's Avatar
I took all my stuff apart and cleaned by my self and it took about 5-6 hours to take everything apart and clean. (about 1.5 hours just cleaning). Then i had help with cam and head reinstall and that took about 4-5 hours. Then i put everything else back on by my self and that took another 4 hours and had it running afterwards. So about 95% work by my self took arround 15 hours. Not bad for my first time.
Old 11-20-2006, 12:26 PM
pennys58's Avatar
I was told somewhere between 4-6 hrs from people who have done quite a few head installs, does this check out to be correct? I may venture into doing it myself and with some help.....Not sure if I want to take on more than I can handle.
Old 11-20-2006, 12:37 PM
LS1TECH Sponsor
foff667's Avatar
took my heads/cam install about 12-15hrs between myself & a friend worth of actual labor, but then we were taking our time & did it through the top rather then dropping the kmember/motor & all.
Old 11-20-2006, 12:39 PM
pennys58's Avatar
Ok, well maybe 10 hrs of labor is correct? Are these other people quoting me 4-6 hrs just out of their minds? I guess Ill find out when this takes place....just debating on whether or not to take it to a shop or try and knock it out myself
Old 11-20-2006, 12:43 PM
Long Beach's Avatar
Do it your self its not verry hard, just time consuming.
Old 11-20-2006, 12:47 PM
Somebody09's Avatar
+1
I probably took 20 hours though. I forgot to unbolt the Y-pipe. That was a ******* pain! And watch your fingers... those cylinder heads can be extremely sharp!!!
Old 11-20-2006, 12:50 PM
Long Beach's Avatar
Originally Posted by Somebody09
+1
Yes they are, i sliced my fingers good.
Old 11-20-2006, 12:55 PM
blkbird's Avatar
Im gonna tackle mine this week starting on Thursday since I will be off for 4 days . I am giving myself plenty of time to get this done right.....
Old 11-20-2006, 12:56 PM
pennys58's Avatar
Haha, thanks for the advice, if i decide to do this on my own Ill definately take that into account!
Old 11-20-2006, 12:58 PM
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
+1
Especially when the socket slips off a headbolt head and you bang your knuckle on the valve cover rail.
Old 11-20-2006, 12:59 PM
2 SSlow's Avatar
alldata calls for like 15 hours...
Old 11-20-2006, 01:09 PM
pennys58's Avatar
hmmmm, i guess ill stick with the 10hr quotes from the shops (if they are going to be doing the labor!!). I guess its not bad then. Thanks for everyones input!
Old 11-20-2006, 05:35 PM
Moderator
davered00ss's Avatar
4-6 hours.
Old 11-20-2006, 05:38 PM
01350ss's Avatar
3-5 hours start to finish. Easy job.
Old 11-20-2006, 05:59 PM
2 SSlow's Avatar
acctually alldata shows 12.7 hours for a 2000 camaro with an LS1. That is what a tech would generally get paid for that job. It doesnt really say how long it will take, but its usually a good estimate.
Jason
Old 11-20-2006, 08:41 PM
pennys58's Avatar
Thanks guys, I really appreciate everyones input......kinda getting mixed answers......I guess Ill split the middle and call it 6-8 hrs. Thanks once again!
Old 11-20-2006, 09:49 PM
SS4Matt's Avatar
depending on how many other problems i ran into while doing it, the cleaning takes the most time of all i think, and one of the most important steps.
I found that the amount of beer drank throughout the weekend of a head swap is relevant to how long it takes the more beer you drink, the less you work....longer it takes
it's a relatively easy swap, and can be done with most simple hand tools,
Old 11-20-2006, 10:38 PM
marthastewart's Avatar
I would plan 10+ hours. Hell most people on here said it took them 4-7 hours for only headers, Thats not even 1/2 way there!
Old 11-20-2006, 11:05 PM
Im on a ranch!
speedybreesy's Avatar
depending on how knowledgeable you are, probably around 6-8 hrs
