Cam Package Need Help
Old 11-23-2006, 11:22 PM
rgk615214's Avatar
Default Cam Package Need Help
So Im wondering do i need the 600 or 800 dollar cam package from thunder racing. I am def getting a tr cam so do i need the dual valve or single valve spring package?
Link: http://www.thunderracing.com/catalog...&vid=3&pcid=51
Ne help much appreciated
Old 11-24-2006, 03:06 PM
tamikews6's Avatar
$539 and $719 now
Old 11-25-2006, 09:19 AM
rgk615214's Avatar
So which one do I need to get???
NEONE?
Old 11-25-2006, 09:53 AM
tmoneyr007's Avatar
By TR Cam are you referring to the CheaTR, TRak, or TRex?
Old 11-25-2006, 10:11 AM
mullenh's Avatar
that depends on which cam you select. which cam are you looking at?
Old 11-25-2006, 10:48 AM
rgk615214's Avatar
im looking at a tr230 or less, i want a cam that wont risk killing my trans. Also, what size could i get that i wouldnt have to use a torque converter with it, like what is the size limit where it would still be drivable without a new stall
Old 11-25-2006, 12:02 PM
rgk615214's Avatar
Noone knows
Old 11-25-2006, 04:45 PM
rgk615214's Avatar
will i need a stall with ne cam???
Old 11-25-2006, 05:09 PM
mullenh's Avatar
well that is easy then if it is the 230\224 you are border line but the cheaper package is fine. anything more and you should upgrade
Old 11-26-2006, 07:27 PM
rgk615214's Avatar
Are there any cams you can use without installing a new torque converter?
