th400
Old 11-26-2006, 12:20 PM
z28boy's Avatar
Default th400
Do you guys have to run a catch can on a 400 with a normal tranny pan. Mine keeps spiting fluid all over and dont know if there is a clearnce problem with bigger or deeper pans or if i should just get a catch can. If some one can tell me where to get this stuff. That would be great.
Old 11-26-2006, 10:46 PM
FLT
FLT's Avatar
Where is your trans leaking from? I really have never heard of a catch can for a transmission.
Old 11-27-2006, 12:42 AM
LS1Tech Sponsor
performabuilt's Avatar
same here never heard of such a thing , Where is it coming from ?
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 11-27-2006, 08:39 AM
SLowETz's Avatar
Sounds like it's purging overfill from the vent tube on top?
Never heard of a tranny catch can..... but I'm sure if someone made one.... someone would buy it
Old 11-27-2006, 11:28 PM
revtime's Avatar
Sounds like its overfilled to me.
Old 11-28-2006, 07:06 AM
FLT
FLT's Avatar
This is true it can be overfilled. On th400's they are very picky and must be filled correctly.
Old 11-28-2006, 04:04 PM
z28boy's Avatar
Yea im going to look at it tonight it seems to be coming out the vent tube all over. Seems to only come out at wot.
Old 11-28-2006, 04:50 PM
Yank's Avatar
If you have a bent blade or blades in the converter it will cause the oil to foam at WOT and expand -- allowing it to come out of the vent
also the Buick GN guys use a overflow bag -- they use a ziplock bag tied to the trans with a rubber hose as they like to overfill the 2004r
but check for the correct dip stick also as the fill line is to the gasket pan surface
Old 08-20-2011, 06:00 PM
black01_WS6's Avatar
I have been having the same problem. I have the madman dipstick, and a brand new FTI converter. Any other ideas rather than a overflow system- I dont want to have a bandaid for the problem. I flushed the oil cooler to see if it was clogged, and everything checked out. I really don't want to drop the entire tranny.
Any other ideas?
Quick Reply: th400
