MS4+ETperformance240cc heads???
Old 11-27-2006, 12:00 AM
BlackSS2001's Avatar
Question MS4+ETperformance240cc heads???
What do you think about this combo???
Magic Stick V.4 239/242, .649"/.609" Camshaft With Your Choice of Lobe Seperation 111deg.
The MS4 camshaft is the result of extensive engine dyno testing & research! Engine dyno results have shown over 80 horsepower gains with no other changes on a stock 2001 LS1 engine!!
2300-6800 RPM Power Band with a peak around 6400rpm
Valve Lift Intake Exhaust Valve Lift
.100" 73 57 .100"
.200" 152 114 .200"
.300" 210 164 .300"
.400" 266 204 .400"
.500" 312 224 .500"
.550" 327 228 .550"
.600" 338 231 .600"
.650" 346 234 .650"
.700" 320 236 .700"
Exhaust to Intake Flow Ratio 73%
Cylinder Head: G III LS1 11° Application: Street / Race
Port Volume: 240cc Chamber Volume: 35cc to 72cc
Test Bore: 4.000" Test Pressure: 28.00" Water
Intake Valve: 2.100" Exhaust Valve: 1.570"
and what is the option 11 deg. rocker pedestal ??? how will that help me?
Old 11-27-2006, 02:05 AM
Collections Hold
Cary@Perf-Induction's Avatar
Default rocker pedestal
I do not like the loobe seperation on that cam. as for the rocker pedestal option, we leave it open, you need them to run stock rocker armas with our heads, they position the rockers properly. if you were to run aftermarket rockers you would not need them.
thanks,
cary
Old 11-27-2006, 08:54 AM
7 Second Club
Phil99vette's Avatar
I'm running 6 more degrees on the exhaust and the car really seems to like it on the motor.
Old 11-27-2006, 10:52 AM
mikeith's Avatar
thanks,
cary
what lobe seperation would you prefer....112? or better yet which CAM itself would you prefer w/ the 240cc's to get the best results
Old 11-27-2006, 11:01 AM
good question!
I'm still lost with the rocker pedistal deal I guess what i'm asking is would I need it... would it help me????
Old 11-27-2006, 01:57 PM
GPowrie's Avatar
Do you plan on running stock rockers? If you do you will need the pedistal option.
Old 11-27-2006, 02:07 PM
no I dont plan on it but i'm not sure if I will want the 1.7:1 or the 1.8:1
Old 11-27-2006, 02:11 PM
I was wondering on the heads What kind of valves, springs, rocker, studs ect.... are in them? (what brand)
It said that they came assembled.
Old 11-27-2006, 05:30 PM
oct03gto's Avatar
WOW! Your using that on 346 ci? I was going to use the same heads FAST 90 intake and a custom 90mm TB with a little bit bigger cam on 408 ci.
Old 11-27-2006, 06:48 PM
KONG's Avatar
Is this going to be in a street car????
Old 11-27-2006, 09:17 PM
rickyracer25's Avatar
Dude call TSP they will max your set-up and get you straight... plus Save you a buck or two good luck.
I think that I remember hearing that one of there guys there is running 475 rwhp with a nitrous tune on the MS4 and PRC stage 2.5 5.3L heads. Then there is TERMINATOR that's pushing 490 rwhp all from TSP
Old 11-27-2006, 09:25 PM
brokeTA's Avatar
well I can tell you that you will never be able to run those heads on a stock engine with the ms4. You will have major clearance issues.
Old 11-27-2006, 10:54 PM
eamador11's Avatar
why such a big runner head?
ETP 215s are designed for 346ci...3.90 bore
Old 11-27-2006, 10:57 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
Originally Posted by eamador11
why such a big runner head? That cant fit on a 3.90 bore
Confused, person who thinks bigger is better.
Just hang around here for a while and you'll learn all sorts of things. I know I have.
Old 11-28-2006, 09:04 AM
7 Second Club
Does anyone have any data that supports a small runner makes more power than a big runner? No theories, hard data.
Old 11-28-2006, 09:07 AM
7 Second Club
So if the 240cc head can't fit on a 3.90 bore how do you explain my 346ci 240cc ET head 3400lb car going 10.4 @ 132 in 875' weather?
Old 11-28-2006, 01:01 PM
7 Second Club
I dont doubt you were able to bolt it on the block. But then arent you
ultimately putting a 4.00" bore head on a 3.90" block?
Then I would think the head is not being fully maximized to its potential. Im
just going by theory and what ive learned on here. with all do respect, I think
its great your setup can run mid 10s, but you got there in an "unorthodox" way.
The runner size has nothing to do with being used on a 4.0 or a 3.90 bore. My heads were setup with a 240cc runner and 3.90 bore. Jon Kaase did some testing and did not find anything to support smaller runners made more power at any RPM.
Old 11-28-2006, 01:19 PM
Beast96Z's Avatar
You also have a solid roller track application. It does what it is intended to do, go to the track. I'm sure you'd agree that it is not the ultimate mild hydraulic cam set-up. Would I run the 240's on a stock bottom end hydro car? No. It would be 225's for me.
So your saying that the 240 head should out power a 225 or 215 head at any RPM givin the same set-up? I don't agree with that. The smaller head will make more low speed HP/TQ, but the bigger runner head will make more power, just at a higher rpm, at the sacrifice of low speed power.
Old 11-28-2006, 01:24 PM
7 Second Club
Your right, I'm not 100% happy with my combo. **** its got less lift than most of the new cams on the market. If I were to do my setup again, I'd use a hydro LSK setup with 240cc heads. Can't remember but I thought brian tooley did some dyno stuff with a larger intake runner with more flow and it picked up pretty good on the dyno.
Old 11-28-2006, 01:40 PM
Beast96Z's Avatar
I'd like to see a 255/263 .663/.663 LSK in there if you don't mind.
