Best car for conversion
Hi,
I have recently started thinking of starting a project car that I will eventually swap an ls1 into. I am not that loyal to any brand and I don't mind cross-breeding. I have thought of using 87-93 mustang, but what else is out there? The mustang follows all of my criteria. I like its suspension(simple yet effective 4-link type design out back, and struts up front), there's a huge market for suspension and body parts, and it has an engine bay that is easy to work in, and it can be light(under 3000lbs), and it looks good to me. What other cars follow this criteria? Here's what i have thought of so far:
94+ mustang-heavier but otherwise similar to 87-93 mustang
mid 90's firebird-like the body style, but looks hard to work on engine
80's monte carlo-heavy and unfamiliar with suspension abilities
s-10-low on my list since i would probably want to do backhalf with a truck(lots of money)
what other cars do you guys suggest? thanks for any suggestions!
I think the S13 or S14 Nissans (240sx) are pretty popular too. Pretty much anything is a good candidate as far as I'm concerned. You basically have to decide what you want to do with it, then go from there.
ck out the rear drive volvos. i'm loving my 94 940. weighs 3350 wet. 4.10 with eaton locker standard. lots of support from jtr. did a 13.9 1/4 today (on street tires 225/50 16 on 16x 7.5) on a g-tech.
Second and third gen RX7s are great swap candidates. Second gens are inexpensive and third gens handle great and look very impressive. Both weigh about 2800lbs and have 50/50 weight distribution. The rear ends are IRS, but don't have any trouble handling the power of a mildly modified LS1. Check out www.torquecentral.com
Pete
Pete
thanks for the great replies and help. I guess the car would be more geared to the dragstrip, so I think i would prefer a solid rear axle rather than the irs. Also, i kind of want to use a domestic car, just a personal preference.
if you want to go drag racing mustangs probably your best bet.
Nissan S13 and S14 240SXs have IRS, Mazda RX7s have same problem. both weigh around 2600-2800
i picked a Datsun 240Z. also an IRS car, but i backhalved it. Also, the weight is very attractive (it will be around 2000lbs)
Originally Posted by THE_SUPRA
do a little british car... talk about sleeper
checkout www.locostusa.com
You can build everything from scratch, buy the frame, buy a kit, etc...
