Big stock cube cams (Trex, MS3/4, etc.,) in strokers (400"+)
How do the big cams that you guys are putting in stock cube motors running in a stroker? Does it kinda make those big cams small cams? Just curious if anyone was running like a 403 LS2 with an MS3, MS4, Trex?
I know someone that went from an LS2 to a 402 with an MS4 in both. The cam istn too big to begin with but a lot more taming in larger cubes. The larger cubes make up for the lost torque that big cames offer in smaller cubes.
Super Hulk Smash
Exactly. You don't need to overcam a big engine to make big power. An MS4 or T-Rex would be pretty good cams in a 402 for example with a FAST 90. The FAST restricts the peak torque to 4800 and the peak horsepower to 6300-6400. The VEs for that means an IVC (intake valve closing) of around 50 degrees at .050" on a 402 will make the best power under the curve while delivering an awesome peak.
The T-Rex offers an IVC of 49 and the MS4 offers an IVC of 48.5 degrees as both offer 2 degrees of advance ground in. So, they will peak a little earlier than 6300. But, you have a good match to your intake for the given CID.
The MS3 on a 113 with no advance has an IVC of 51.5, which is also very good. Because it's a little smaller duration wise, it will still make the torque with the higher IVC (also due to the EVC or exhaust valve closing). I actually like the MS3 as a very good overall power cam for a 402. I've seen 515rwhp 495rwtq out of small port headed 402s with the MS3. I don't know about you, but some of the huge cammed, huge ported heads are only around 520-530rwhp with 460-470rwtq. I'd gladly give up 5-10rwhp at peak for another 30rwtq everywhere below 5500.
Well said words of wisdom and I agree 100%
search is your friend I asked the same question (sort of) almost 2 years ago.
https://ls1tech.com/forums/generation-iii-internal-engine/277458-not-your-everyday-cam-question-regarding-big-motor-small-cam.html
https://ls1tech.com/forums/generation-iii-internal-engine/280975-408-stroker-guys-inside-please.html
Yeah, jake has it on the money, I run a 232/234 113 49 IVC in my 370cid and the numbers speak for themselves. 6200 peak (carries to neverland) and 4800 trq peak
(Ported BBK/80mm modified LS6)
