Whats the max valve lift on stock LT1
Assume you have a completely bone stock LT1 engine. What is the maximum valve lift you can goto without hitting the pistons? I'm sure there's more involved than just the lift so, at least, where is the safe zone and where does the danger zone start?
Well, I started wondering when I read the "another cam thread" thread about this and I didn't want to hijack his. I dont know if my computer is screwed up or something but, the search hasn't worked the last like 3-4 times I went to use it so, sorry about asking this if there's already another thread.
Originally Posted by streetwarrior96
Well with the LT4 Hot cam you already need to upgrade. I have a friend running stock with the Comp Cam 503
I would assume you can go higher than any shelf cam has in it. The gaskets are about .050 thick and the pistons are about .025 in the hole. The LT1 chamber is much smaller than other sbc, but I think you'll be ok with about .650 or so. What were you planning on running and why were you going to do it on a stock LT1 shortblock? Most LT1 cams that people run on stock blocks are around .550-.590 valve lift.
I had a cc305 on stock springs before never had a problem but i know that a hotcam requires new springs. Ive always been told that .510 is the max lift for the springs before they would break.
Originally Posted by seawolf06
Wouldn't it be a combination of the two? This is interesting.
It has to do with the piston being up around TDC and the valves are both open.... IF you open the intake valve sooner and close the exhaust valve later then P to V will tighten up. So to put that in laymens terms.... lower LSA or higher duration or both will tighten your P to V.
As for the lift last time I checked you could do over 1" of lift without problems there.
Bret
Bret
Generally the rule is you look thru that chart and find the coil bind height add .080" to that number. Subtract your installed height from the number you just got and that's the max lift.
Depends on the valvetrain but you can push that coil bind number tighter if things are correct.
Bret
Bret
