bbk 80mm throttle body
where can i get the gasket set for the throttle body i think it flat type on the other side is the o ring type wich is on the intake but i need the one that goes in between the throttle body and spacer
What do you mean, there is supposed to be a gasket for the BBK Throttlebody?
I bolted mine up to the LS6 intake, used some sockethead cap screws as the original ones wouldn't fit. Everything went back together after trimming the bellow a bit. Car runs fine, excluding a minor coolant leak (either I didn't get the coolant lines on it properly or I damaged one of the pipes on the throttlebody).
Originally Posted by bigpappasz28
to whs it does have a gasket between the throttle body and black spacer
Did yours come with different bolts?
i think then you have smaller than 80 mm because i tried to put in on with out the spacer and the blade hits the intake it will not clear the opening due to larger throtle plate
