What is causin my cyl 4 misfire
ok so i swapped everything as some of you know and it stayed with cyl 4, today i start messin around with my car again and i take my plug out, well i can smell some oil on it and i did a compresion test and got 120 psi? so what do you guys think? is there oil gettin through my valve seals or could it be something else. Let me know what you think. Thanks al ot
no its gapped the same, it is making noise but that could be my new exhaust leaking, i will clamp it off toniht or tomorrow and i bought a stethscope so i will use that, and im about to do acompression check on another cyl...but is 120 usually fine?
Usually most engines are around 150-170 depending on the compression ratio. If you want to eliminate plug, wire, and coil, switch the plug with another cylinder...does the problem move or stay? then switch the wire...then the coil...if the problem still stays with the cylinder, you may have a sticking valve.
What all have you checked?
i did another compression test today and got 150 psi then cranked again and again and got nothin and then again got 150, took my valve cover off and this is what i got....
URL=http://imageshack.us][/URL]>
Originally Posted by joshp14
Ouch! I'd say its bent a little! Over-rev your engine at one point? Time for some chromemoly pushrods...
That is a hell of a bend....good job How the heck does it even fit in the pushrod bore with a kink like that?
i dont really rev my car to high, maybe up to 3500-4k but yeah thats one hell of a bend, just glad it was nothing to bad, now i can fix it and stop driving my geo metro haha. It was nice saving the gas for a few weeks drivin it but it is still not worth driving it.
i am going to get some LS6 heads and a cam but not to sure what cam i wanna go with because i am pretty sure i wanna procharge it later on. For riht now i will drop the new push rod in and just drive it and i will make it a weekend project to do those things, right now i should save a littl emoney. I could get either the heads or cam right now but im just going to get them both togther at the same time, just tryin to save up for school and i wanna start buyin more stuf for my Turbo Regal. I really only bought the TA to be my daily driver so i could build the tr up hardcore but it looks like they are both gonna get built up pretty good. i knew id do this...oh well.
guys today i tried to install my new push rod...well i notice some things, the hole in the head was grinded a little bigger from that push rod rubbin up against it and i dont think thats a big deal but i tried putting my new one in (the new one is 7.400) and it doesnt reach the the rocker arm, i had the rocker tigthened down and its not reachin. it is pretty far off. so whwat do u think about this? i was thinking maybe my lifter is bad but im not sure.. let me know what you think.
