Sponsored by: CARiD
what does your car idle at?
Old Nov 5, 2006 | 03:53 PM
victimizati0n's Avatar
Default what does your car idle at?
Im just wondering what the norm is... im mainly looking for stock engines, LS1.
thanks
Old Nov 5, 2006 | 04:01 PM
Pewterpower's Avatar
A4. In gear, 500.
Old Nov 5, 2006 | 04:06 PM
01Z28MN6's Avatar
mine if i remember correctly idles about 750 or so. This is according to autotap. M6, 2001
Old Nov 5, 2006 | 04:08 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
All LS1 years M6 are set to 800rpm idle.
All LS1 years A4 are set to 650 park/neutral, 550 in gear.
The stock tachs aren't perfect, so you may see different readings on the gage. A scanner is the only way to tell for sure if the car is idling at the proper RPM.
Old Nov 5, 2006 | 04:11 PM
2001NBMZ28's Avatar
Yeah, M6 are higher. On a scanner (warm) my stock A4 in gear idle was 525-585, Park/Neutral 645-676.
Old Nov 5, 2006 | 04:13 PM
wtf, mine idles at 1000 cold, and 900 warm, i drive a manual
Old Nov 5, 2006 | 04:15 PM
yeah, i guess this could be the case.
too bad i cant afford a scanner (unless they make a cheaper one that i can look teh idle up)
Old Nov 5, 2006 | 04:18 PM
Mike02Z's Avatar
about 800 warm for my 02 M6
Old Nov 5, 2006 | 10:38 PM
GC456's Avatar
950 warm
Old Nov 5, 2006 | 10:42 PM
Revelation Z28's Avatar
1000 cold and hot idle in gear or neutral.
Old Nov 6, 2006 | 01:03 AM
2002_Z28_Six_Speed's Avatar
That is fine. Don't worry about it.
Old Nov 6, 2006 | 01:10 AM
SpaZMaN's Avatar
very true, my does about the same. cold idle can be from 1200-800 for me, but thats REALLY cold
Old Nov 6, 2006 | 01:30 AM
BayAreaSS's Avatar
My M6 idles at 1000 when cold and about 850 when warm
Old Nov 6, 2006 | 06:19 PM
2001somws.6's Avatar
Same here. Not a problem.
Old Nov 6, 2006 | 06:32 PM
TORCHD 02 TA's Avatar
My M6 idles at 500 - 600 RPMs
EDIT: had the car out last night. cold was about 1000 RPMs and when it was warm it was at 800-900 RPMs
Old Nov 6, 2006 | 08:22 PM
blkbird's Avatar
Mine is about 750 warm...
Old Nov 10, 2006 | 02:07 PM
gun5l1ng3r's Avatar
My M6 idles at 1100 WARM and about 1300 COLD. But when I had a smog test and the scanner was hooked up, the computer said about 800 rpm WARM idle.
So my factory tach is off about 300 RPMs.
Old Nov 10, 2006 | 02:12 PM
kaos_'s Avatar
I'm a hare below 1000 when it's warm. Is that normal for my setup? Seems to be running cherry though.
Old Nov 10, 2006 | 03:04 PM
NHRAMAN's Avatar
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Exclamation
I set mine at 550...doesn't need to be any higher..used to idle at 750..thought i would try lower and see what that was like..smoother and alot quieter.
Old Nov 10, 2006 | 05:35 PM
Z28LS1camaroguy's Avatar
900 cold and 700 warm, in park idles at 800-850 and i drive an A4 but i have a tune also.
