a/c system
Old 12-15-2006, 05:25 PM
99kamarokid's Avatar
Default a/c system
how hard is it to remove the a/c system on my 99 camaro...and another random question, my water pump is leaking, is there a better one i can replace it with instead of an ls1 water pump...and not a electric one, thanks
Old 12-15-2006, 08:23 PM
blue01ta's Avatar
I don't know if the camaro and the t/a's are exactly the same but I imagine they are close. Most of the a/c system is a piece of cake to remove. The evaporator core in the dash is a pain. You pretty much have to pull the dash. I pulled everything but the evap. You'll be surprised how heavy the comp and the brackets and bolts are.
Old 12-16-2006, 02:43 AM
chrs1313's Avatar
just the system in the engine bay will take less than 45 minutes...if you wanna dive in the dash good luck could take a while
Old 12-16-2006, 03:43 PM
black_z's Avatar
How much does the stuff under the dash weigh? Isnt the total reduction about 40 lbs?
Old 12-16-2006, 05:16 PM
blue01ta's Avatar
It can't be very much. I rarely used my a/c and it was costing me a little hp and weight so I pulled it off.
Old 12-16-2006, 05:54 PM
chrs1313's Avatar
well the engine bay stuff weighed 33lbs for me
Old 12-16-2006, 06:04 PM
...with cheese.
Armageddon's Avatar
Easy, do it if you don't use it.
Old 12-16-2006, 06:27 PM
yea, im not going to go that drastic with ripping my dash apart, but i want everything in the engine bay gone, but there are a few hoses and stuff...is there a write-up on it, or any things i should watch out for?
Old 12-17-2006, 06:34 PM
blue01ta's Avatar
I don't know of any write ups on it. Just get under the hood, it's very simple. As far as the belt goes I just cut it with a pair of wire cutters. The only thing you really need to worry about is getting the freon removed from the system before you start pulling it apart. After that just start unbolting things.
Old 12-18-2006, 01:49 AM
how would i empty the freon, and where should i plug the hose?? any suggestions would help, thanks
Old 12-18-2006, 05:08 PM
chrs1313's Avatar
use a screw driver and a towel...just push it in on the valve by the condenser...then take everything out...not to difficult
