10 second bound!!!!!
Old 12-17-2006, 06:25 PM
10secLT1's Avatar
Default 10 second bound!!!!!
Old 12-17-2006, 06:43 PM
MEAN LT1's Avatar
Before anyone asks, you may want to post your setup.
Old 12-17-2006, 06:51 PM
97blkz's Avatar
I heart 10 sec lt1's!
Old 12-17-2006, 06:55 PM
Ralls's Avatar
You got anything stock still on it?
Old 12-17-2006, 09:02 PM
moserman's Avatar
i agree with MEAN LT1, post your setup before you have people thinking you really are in the 10's when for all we know that could be a rolling chassis sitting on that trailer. dont bragg unless you can back it up!
Old 12-17-2006, 10:16 PM
Snyper's Avatar
10's on street tires..woo hoo
Old 12-17-2006, 11:09 PM
10secLT1's Avatar
383 lt1 ( JE pistons, scat crank & rods)
stock castings (mild port work & bigger valves 2.0 1.56)
erson custom grind cam (nothing speacial)
P/C longtubes & 3'' borla
NX (150 shot)
madz28 base tune (still need to data log)
17'' M/T et streets 26x11.50
spec stage 3 clutch
eibach sportlines
STOCK: tranny, rearend, suspension, intake manifold, TB, ignition, shocks.
full street trim 3480lbs
Old 12-17-2006, 11:12 PM
10secLT1's Avatar
do you mean as in street legal D.O.T approved, yes.
Old 12-18-2006, 12:06 AM
Gun5's Avatar
hell ya man
Old 12-18-2006, 04:57 AM
slowmofo's Avatar
Thata a mean looking car... I heart T/A's
Old 12-18-2006, 08:46 AM
ABA383's Avatar
Nice car, I'm somehow partial to black...I'm trying for 10s, too, N/A...we'll see next year...
--Alan
Old 12-18-2006, 09:06 AM
Chevydomination's Avatar
Stock suspension, wow that's impressive
Old 12-18-2006, 09:12 AM
97blkz's Avatar
I cheat on the suspension with LCA's and relocations.
Old 12-18-2006, 10:13 AM
lt1formula2000's Avatar
10 bolt is still in one piece behind a m6 thats impressive
Old 12-18-2006, 10:31 AM
Hot94Z28's Avatar
Yeah that is.
Old 12-18-2006, 10:47 AM
Moderator
BizZzatch350's Avatar
Good luck with your journey to the 10s!
Old 12-18-2006, 05:13 PM
OutlawZ's Avatar
good luck... that is enough oats to run 10's... I went 10.40 with a similar setup only i had a 355 with forged bottom end, H&C and 150 shot (thru a TH400 on slicks however)
I'd definitely dump that rearend though..... running what you'll probably run that rear will give up the ghost causing you some problems eventually..... the other reason is that at the track if you have to baby it out of the hole for fear of crushing the ring gear you're going to give up a TON of time to cars with less power but more durable parts.... just my opinion... nice ride either way......
Old 12-18-2006, 07:35 PM
10secLT1's Avatar
do you guys think a th350 would be good for this car, street/strip.
p.s any feedback will help.
Old 12-18-2006, 08:07 PM
Moderator
Depends on the stall and gearing, I have a couple buddies with th350s, I wouldnt want to daily drive any of their cars but their ok to drive other wise.
Old 12-18-2006, 09:55 PM
97blkz's Avatar
Strip it's bad ***, street uhhhh not so much. Let me ask how much you hwy drive? Where do you live, I have a 4l60E done locally(tampa) and have quite a few 10 second passes. They can be built to handle it but just not many know how. If interested I'd let you know the shops name.
Quick Reply: 10 second bound!!!!!
