vacuum pump.............
Old 12-17-2006, 10:02 PM
SSwanner's Avatar
Default vacuum pump.............NO MORE PCV!!!!!!
well i'm sick and tired of fighting with the LSx pcv system
i did some digging and found a company that makes a vac. pump kit for us! it is $700 though i guess i'm just looking for input from some of you and some opinions.
linky to fix
Old 12-18-2006, 12:56 PM
SSwanner's Avatar
18 views and no replies...
Old 12-18-2006, 02:47 PM
zfastss's Avatar
From what I understand, vacuum pumps are not all that practical on daily drivers, they're more for an all out drag application. That's pretty much the extent of my knowledge, maybe someone else can chime in with better info.
What caught my attention is that I know the owner of the company that you posted the link to (he's my boss' father), and he told me a while ago that that kit was developed around the corvette accessories and engine bay and would probably need modification for f-bodies.
have you tried some of the cheaper possible fixes like a catch can?
Old 12-18-2006, 10:12 PM
SSwanner's Avatar
well the car is only my race/fun car, not a DD. i've tried a catch can/oil seperator/breather, they all pretty much just suck.
i seen it was fit for the vette but it looked like it would fit on a f-body pretty easily.
Old 12-19-2006, 09:37 AM
11 Bravo's Avatar
Damn, I need that for an f bod.
Old 12-19-2006, 10:53 AM
C_Williams's Avatar
here's a Vacuum Pump kit that works on an F-Body - a little more money, but then it's the original idea that's been copied by others and maybe they can only compete on price
These kits are available with 3 vane and 4 vane pumps, adjustable regulators, and a oil separator/catch can.
Old 12-19-2006, 02:13 PM
zfastss's Avatar
I'd give the guy a call (link in the first post). He really knows his stuff and he did tell me that he has a customer with a camaro and one of his kits, so maybe he could describe what if anything had to be modified.
Old 12-19-2006, 02:32 PM
SSwanner's Avatar
i'd like to see/hear more about the other pump posted for sure.
can you ask the guy a little more about putting it on an f-body?
Old 12-19-2006, 02:43 PM
7 Second/200 MPH Club
CorvetteMajor's Avatar
I ran that system for the past two seasons.
Works great
Old 12-19-2006, 05:01 PM
SSwanner's Avatar
Works great
which one? can you give me some details on it?
Old 12-19-2006, 05:55 PM
11 Bravo's Avatar
I sent him an e-mail. This was his reply:
A 99 F body should be similar. The key is this. The vacuum pump fits between the belt tensioner and the water resevoir in the C5. We replace the tensioner pulley with our own and mount the pump on the pass side head. It fits perfect. So you should have an LS1 which is what it is designed to fit, and will fit as long as the tensioner is in the same location as the C5. If for some reason you have an LT1 then our standard mounting kit using a separate crank pulley and mount off the head will work, but you do need an after market bolt on keyed balancer. This assumes you have the room infront of the serpentine and balancer for another pulley, which was the problem with the C5
Hope we can help.
Old 12-19-2006, 05:58 PM
ls1408cp's Avatar
vaccum pumps are made for power not to catch oil. You will fill the tank very fast if you drive it around.
Old 12-19-2006, 06:01 PM
11 Bravo's Avatar
Yes and on big engines that suck up vaccum they can make a good bit of power. And in fact reduce oil consumption. Of course they don't "catch" oil lol
Old 12-19-2006, 06:04 PM
ls1408cp's Avatar
they do catch oil. When you suck it up with the pump where do you think it goes. Their are certain reasons to have one but 99% of cars on here dont need one.
Old 12-19-2006, 06:42 PM
11 Bravo's Avatar
So what determines when an engine needs one?
Old 12-19-2006, 07:04 PM
ls1408cp's Avatar
you can do it like that or just mount a breather to the center cover or valve cover
Old 12-19-2006, 07:24 PM
11 Bravo's Avatar
That setup is nice, but I already have a catch can (not as nice a setup as that). A vacuum pump sucks air out of the crankcase caused by blowby, which is compressed a/f getting past the rings. A catch can doesn't do that. I want a vacuum pump. Just a small one.
Old 12-19-2006, 07:44 PM
11 Bravo's Avatar
This is the C5 vacuum pump
Old 12-20-2006, 08:37 AM
C_Williams's Avatar
The kit in my post...Paul runs the three vane kit and it looks like this..
Three Vane Pump Kit
Four Vane Pump Kit
Old 12-20-2006, 08:53 AM
11 Bravo's Avatar
Who makes it?
