Converter question
The converters are completely different. The transmission uses a different input shaft, and the converter bolt pattern is different also. The LT1 (and LS1 Corvette) used a 298mm while the LS1 used a 300mm design.
Hope it helps.
Hope it helps.
Hope it helps.
Hope it helps.
