Dart 205 or 215 for DD?
I would go with the 225's if you had a cam with more lift like say the lsk lobes so you could take advantage of the flow past .600 inchs but with the torquer i defintally say the 205's. As for PTV you'll be perfectly fine with stock gasket thickness but if you are pulling th heads i would recomend running .040 gaskets to up the DCR but even with that i think you'll be fine on PTV, but measure just to make sure
Justin
Justin
Originally Posted by duece_bigalo01
I have the 205s in my car with the MTI C1 cam and I love it. No complaints here. And its my daily driver.
Ben T.
When you say the heads are cut 0.08 do you mean milled? I know mine have been milled a little like 0.02 and my compression was around 11.3 to 11.5.
