Tuning for Nitrous
Tuning for Nitrous
Hey guys, just had a quick question. Is there any way that you can make a tune for N/A and Nitrous on the same file with LS1 Edit? What I'm getting at is can you set up timing for N/A in your high octane table and then lower it down for your low octane table? I know that it won't be a really good tune spraying, but if that would work you could still run good N/A, then you would just be running a tad rich spraying if you cut the timing out of it when it jumped to the low octane table. Me and a few of my buddies are on the same cable for the Edit and they aren't all local so I won't have the laptop to change the tune whenever I want, which is why I'm asking. Any other ideas if that won't work? Is that even safe if it would work? Thanks in advance guys!!!
for a dry shot...
Take a look at Robert56's website. There's detailed instructions on how to do it. I could tell you here.. but you'd need the secret decoder ring first.
ok, j/k..
ok, j/k..
Originally Posted by Todd157k
for a dry shot...
ok, j/k..
ok, j/k..
https://ls1tech.com/forums/member.ph...oster&t=652462
He changed his user name to reflect his Vender Sponsor Status
