Guys With 6.0 Iron Blocks Come In
Alright I Buoght A 2000 Short Block,is This Year Any Diffrent?also I Need To Know The Exact Size Drill And Tap I Need For The Bolt The Holds The Alternator Bracket.also Since The Block Is A 2000 And I Have 317 Heads To Go With It,what Head Studs Do I Buy?regular Or 2004 Up I Believe It Is?
If it is truelly a 2000 engine, it is an LQ4. The tap for the alt is an M10, can't recall the thread pitch though. The head stud should be the unequal length ones, not the set that is all the same size.
LQ4 = dish piston = 9.5 CR
LQ9 = flat top pistons = 10.4 CR (IIRC)
The LQ9 was not available until 2001, that is when 317 heads started becoming standard on Iron 6.0L engines. The LQ4 and LQ9 are identical, except for the piston design.
Ohh So Boosting A Stock Lq4 Is A Good Thing Then,but Even With 40kmiles Should I Trust It?
Originally Posted by kwman
Can you put aluminum AFR heads on the LQ4/9? Kind of off topic I know...but I'm a little curious.
