tuning help needed. no manual shift at wot
Old 12-28-2006, 10:24 AM
hoover112's Avatar
Default tuning help needed. no manual shift at wot
99 f body 4l60e. i noticed that my car will not manually shift at wot. it hits the rev limiter on the 1-2 shift if you move the shifter up to second when it is time to shift. i suspect it has something to do with my pcm tuning since my rear gear was changed from 2.73 to 3.73. a friend recalibrated the speedometer with his flash software but did not change any of the shift settings. the trans shifts great in the overdrive and drive position and will manual shift at part throttle. i hoped that maybe someone else has run into this before and could tell me how they corrected it.
Old 12-28-2006, 10:33 AM
LS1Tech Sponsor
performabuilt's Avatar
Im not real familar with the tuning aspect but I do know that tuning for a diffeent gear requires changing the shift rpm as well as ajusting the speedo calibration , Im sure someone here will have and answer for you
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 12-28-2006, 10:45 AM
hoover112's Avatar
i was thinking on the same lines but i'm not sure quite where to start. i figured the shift mph would be off since the gear was changed but im not sure why it only affected the manual shift. i will have hp tuners soon and im looking for some insight on where start correcting this. is there seperate tables for manual shift settings and overdrive settings. thanks for your help
Old 12-28-2006, 11:21 AM
jmm98LS1's Avatar
In order to shift manually like you're trying to do (not sure why you want to, the pcm shifts faster than you can), you need to install a shift kit that will allow you to hold any gear manually (transgo HD2 for example.)....In stock form, you can't manually shift a 4l60e like you're trying to do, no matter what you change in the tune.
Old 12-28-2006, 11:48 AM
hoover112's Avatar
the reason i want to hold it in 1st gear is when the car is spinning i need to pedal the car some. when i pedal it it shifts to second. once it stops spinning, i go back wot and it downshifts back to 1st. then is starts spinning real bad. to further elaborate on my shifting problem, even when you move the shifter up to second gear at 5000 rpm it still bangs the rev limiter. the only way for me to avoid the rev limiter is to make the whole pass in drive or overdrive, which isn't possible for my current combination. furthermore a friend has another f body, same year that will manually shift at the shift point just fine. same rear gear, same trans builder, same internal trans modifications. the only difference is his has a hypertech programmer to calibrate the rear gear change with. that is the reason i am looking for some tuning advise.
Old 12-28-2006, 12:36 PM
GT Griller's Avatar
Yea after i chaged my gears the shift point changed aswell.....i would look into that first.
Old 12-28-2006, 01:08 PM
hoover112's Avatar
what i was hoping for was someone to chime in and tell me they run into this and tuned around it. i need to know what to change once i receive my software.
Old 12-28-2006, 01:12 PM
LS1Tech Sponsor
well about 85 percent of the country is probably at work right now but Im sure that once the normal trollers get on they will chime in , Good luck
__________________
Call 888-744-6542
