supercharger or turbo
what have you guys had the best results for the ls1 with, supercharger or turbos. i see a lot of guys with both. what are the benefits of each. also how much boost could i safely run thru a 408 iron block all forged internals. i was thinking about running around 12 psi.
15psi? Whoa, that's gonna be $$ just getting that to the ground.
Originally Posted by barthowell
what have you guys had the best results for the ls1 with, supercharger or turbos. i see a lot of guys with both. what are the benefits of each. also how much boost could i safely run thru a 408 iron block all forged internals. i was thinking about running around 15 psi.
Prepare to be yelled at by a lot of people.
I'd check the stickies at the top of the forum and also try the search function (if it is working today).
But... since I'm bored I'll give you some quick links to some helpful threads (there are some better ones out there, I just can't find them quickly enough right now).
forced induction rankings
TRT vs Procharger
There is a hell of a lot of information in this forum if you look hard enough...
STS vs Procharger
TRT vs Procharger
STS vs Procharger
The ATI ProCharger is a well proven method of going with forced induction. Order it and have it on within two weeks. I'm still not convinced there is a good turbo kit on the market. Many companies have tried to come out with a turbo kit, and many of them have taken deposits, but have gone under before getting the kits to their customers. When an oem company puts a turbo on a new car, they spend millions in R&D, the aftermarket just can't afford to do this.
The link directly below may help you out. Bob
http://www.exoticperformanceplus.com....html?item=798
http://www.exoticperformanceplus.com....html?item=540
http://www.exoticperformanceplus.co...x.html?item=798
http://www.exoticperformanceplus.co...x.html?item=540
EPP has a lot of experience with this, both the STS turbo and superchargers. The supercharger will whine, they all do. The STS has a lot of piping, which can be an issue. For either, you will need an intercooler.
And you will have to mod your suspension to get the power to the ground, as stated before.
Best of luck.
Best of luck.
