9C1 tranny in f-body
Old 01-06-2007, 09:16 PM
VIPER EATER's Avatar
Default 9C1 tranny in f-body
hey guys just wanna know if this will work buddy of mine had a 94 9C1 caprice and when he bought it the guy gave him another 4l60e so im wonderin if it will bolt right it or if the tail shafts are different or what so if you guys can help me out that would save me alot of money right now thanks guys
jason
Old 01-06-2007, 09:57 PM
pcs9449's Avatar
Yes, just change the tailshaft housing and you should be set.
Sean
Old 01-06-2007, 10:00 PM
if i dont that do i have to change the output shaft???
Old 01-06-2007, 10:21 PM
LS1Tech Sponsor
performabuilt's Avatar
A 94 trans is completely different from he 2001 you have in your sig its not and easy swap , Requires special converter or spacers, The electronics are all wrong. At least if im getting this right and your talking about putting a 94 4l60e in a 2001 F body.
Much more trouble than its worth not to say it cant be done it can be done but probably not worth the effort and expense.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 01-06-2007, 10:31 PM
nah this is for my 1995 trans am
Old 01-07-2007, 10:52 PM
if i change the tailshaft housing do i have to change the output shaft also???
Old 01-07-2007, 11:10 PM
LS1Tech Sponsor
ok didnt know that lol , and no you do not have to change tail but you do need to look at the pump and see if theres a PWM on both pumps if not PM me and ill tell you what you need to do
__________________
Call 888-744-6542
Old 01-07-2007, 11:35 PM
whats the PWM on the pump??? so if theres a PWM on the pump from the caprice and not on my bird or vice versa what is it???
thanks for the replys and the help
jason
Old 01-07-2007, 11:50 PM
LS1Tech Sponsor
type of converter clutch contoll if the both do or dont no problem but if one does and one dosnt PM me and ill tell you what to do about it , its not hard
__________________
Call 888-744-6542
Old 01-08-2007, 12:25 AM
great thank you and i will do ill prolly do it next weekend could i give you a call tomorrow if i can whats a good time???
thanks jason
Old 01-08-2007, 12:32 AM
LS1Tech Sponsor
Any time and yahoo messenger also
__________________
Call 888-744-6542
