Dual spring life....
how long do they usually last on average. I just bought some heads, and the guy that i bought the heads from said that there are patriot "gold" springs on there and that they have 5k miles....so when should i expect to swap them out?
O and Torquer v 2 is the cam....232/234 .595/.598 112lsa
I would either change them now or after 5K miles. Two reasons, do you have documented proof of the mileage and secondly you don't know how they were driven. A failure could be costly so I would personally tend to error on the side of caution, especially when it comes to valve train parts that can cause a lot of damage should they fail.
I actually bought the heads off of here. The guy is pretty cool, and told me that the heads and springs were already gone through, but i'm gonna take it to a machine shop.
We have seen customers with pretty large cams that had 25k+ plud and the springs still be within the advertised specs. The best thing would be to check them now so you know exactly what you have.
Well, the pressure tester would give a hint as to how hard they've been run. The spring gets weaker and weaker the more it's used, so a weak spring pressure would show they don't have much left. However, a spring could show proper pressure at the seat and still fail.
