bleeder valve
Old 01-16-2007, 01:59 PM
kilgore's Avatar
Default bleeder valve
can some one show me a picture of where the bleeder valve is on my car. i had it at tuffys and they wanted to remove the transmision to bleed the clutch which made no sense to me so i said no. but if somebody could help me locate the bleeder valve i would apreciate it. thanks. oh and its a 00 trans am
Old 01-16-2007, 02:32 PM
LS1TECH Sponsor
Steve Burger's Avatar
Look at where the hydrolic line goes into the trans. It is about 2" above that. 7/16" shallow socket on a 1/4" breaker bar is your freind on this.
Old 01-16-2007, 03:11 PM
Hugger Z's Avatar
Yeah, it is above the hydraulic line. It is a PITA to access and can be messy. I was able to get the socket on, but not with a breaker bar attached. Then I could not get the breaker bar on the socket. And trying to get the socket back off was next to impossible. Others have had better luck, but my friend and I did not. I just sourced a bleeder extension from Steve-D to put on my car during the clutch swap next month. That will eliminate the problems of getting to it and make the process MUCH easier.
Old 01-16-2007, 09:24 PM
kilgore's Avatar
ok thanks guys im guna attemp to do it on friday so if i cant get it i guess ill come back for more help
Old 01-18-2007, 11:13 PM
kookamunga's Avatar
hell yes! that thing rocks lol I don't need to jack up the car anymore to bleed the clutch
Old 01-19-2007, 08:21 AM
JRracing's Avatar
Post a pic of the after market bleeder.
Old 01-19-2007, 10:06 AM
kookamunga's Avatar
here you go
the line is long enough to be routed allmost anywhere. I have mine up by the clutch master cylinder
Old 01-19-2007, 08:43 PM
03 BUSA's Avatar
does anyone know what the threads are in the slave? I have access to a million used steel braided lines but I can not figure out what the threads are. I have tried pipe and the AN threads and they do not work, the only thing that has come close to screwing in there was a 3/8ths bolt. If I knew the thread I could just screw in a fitting and attach a -3 line with a bleeder attached to the end of it.
Old 01-19-2007, 10:51 PM
SSwanner's Avatar
where do you get the bleeder extension? price?
Old 01-20-2007, 05:27 AM
kookamunga's Avatar
go here
http://www.frrax.com/rrforum/index.php?showtopic=6750
Old 01-20-2007, 09:52 AM
bayer-z28's Avatar
^ That might even work for a one person bleeding job, just temporarily route it under the car..
Old 01-20-2007, 10:32 AM
kookamunga's Avatar
it comes with a speed bleeder so you can do it solo
