question
I continue to use Dex-cool. The Prestone "pre-mix" as they call it is pretty darn expensive, though. When I did my cam swap I bought 3 gallons and it was over 30 bucks at Pep-Boys.
You will see a "Orange vs. Green" camp here though
R/
Frat
R/
Frat
LS1Tech Administrator
Received 1,492 Likes
I use only Dexcool (Prestone version) in all my GM cars including my LS1. No problems after all these years. Just don't wait 150K miles to change it like GM recommends, and don't let the cooling system run significantly low on coolant.
The coolant isn't the problem. That stupid-long change interval that GM recommends is the problem.
Originally Posted by staringback05
we actually use that "pre mix" stuff in our patrol cars......for what they go through it works VERY WELL
ANYWAY I use dex-coolant and always did in my LT1 and now in my LS1 no problems... ever.
+ I hear it's a .000000000000000000000000000000000001 rwhp gain
btw here is an easy way to mix.... buy:
One gallon of dex-cool (~$10)
Two gallons of DISTILLED water...
Add the coolant and fill until radiator stops bubbling the coolant down. Idle the car until it reaches operating temp, keep topping off and it should take the whole bottle of dexcool plus about 1.2 gallons of water.
