Tranny problems please help !!!!
i have a Rossler stage III tranny in my V6
back in may the motor took a dump
about 3 weeks ago i got the new motor back in with the same trans
hooked it up and its throwing
it throwing:
0740 TCC enable
0753 1-2
0758 2-3
0785 3-2
1860 TCC something
i thought it wasn't pluged in all the way so i tried to plug it in more.... and i push the plug down into the tranny
Today i took the tranny pan off and push the plug back up in there and pluged the harness back in. refill with tranny fluid
AND I GET THE some thing... i even cleaned the connector for the harness
i also checked the connections at the PCM they look fine and the harness plug looks fine also....
i don't know what else to try/do i know nothing about auto's lol
the tranny will not throw the shift codes unless the car is moving and it don't shift..... you can feel that the tranny it not shifting at all.....
please help
it throwing:
0740 TCC enable
0753 1-2
0758 2-3
0785 3-2
1860 TCC something
please help
Originally Posted by performabuilt
Ill send you a pin out diagram shortly get yahoo messenger so its easy to file transfer everything you need
thanks !!!!!!!!!!!!!
not out of the woods untill i go for a drive but
when i converted my car i had to run wire off the free IGN port in the fuse box... to a wire in the harness......
I FORGOT ABOUT IT i cut it getting the motor in cause it was in the way lol
thanks performabiult !!! << helpd me on saterday and i never bought anything off him
Did you get to test it yet ?
Ok well let me know ,
THANKS
you didn't have to help me at all, let alone on saturday
