tach signal-4 pulse to 8 pulse??
Old 01-20-2007, 09:03 PM
chrisp3's Avatar
Default tach signal-4 pulse to 8 pulse??
Is there anything that will convert the tach signal (the 4 pulse) so the factory tach will understand it? working with a 98pcm/69 camaro
I have seen a signal generator for the vss to convert to cable (in order to use the factory speedometer) but haven't come across anything that will convert the LS1 signal for the tach.
Anyone?
ChrisP
Old 01-20-2007, 10:14 PM
sawzall wielding director
G-Body's Avatar
HP Tuners or EFI Live7. You don`t need any external box or convertor. Just have whoever is reprogramming your PCM set it up. BTW the factory LS1 tach signal is a 2 pulse per rev and the tach for your camaro is looking for 4 pulses per rev not 8.
You could also get a convertor box from dakota digital, or baker electronics(check e-bay), but I think it is much easier to just change the parameter in the PCM.
Old 01-20-2007, 10:26 PM
the_merv's Avatar
It is a thing that can be tuned. I am looking at the same thing when I do my swap.
Old 01-21-2007, 12:58 AM
Rodder's Avatar
Just fixed this on mine this afternoon--much easier to fix in HPTuners than pulling the gauge back out. I'm using a 99 PCM, not sure if the 98 has the same option--apparently it's OS dependent. Stock, both of the "tach resolution" values are "6". Change both of them to "3" for an 8-cyl tach.
Old 01-21-2007, 05:13 PM
chrisp3's Avatar
G-BODY- Thanks for the correction on the pulses. Looks like thats the way I'll go when I hand my pcm over to MTI.
Rodder- When you wrote, "Stock, both of the "tach resolution" values are "6". Change both of them to "3" for an 8-cyl tach" is that the same thing as going from 2 pulses to 4 pulses?, or does your statement pertain to HPTuners only.
Thanks for the help
ChrisP
Old 01-21-2007, 06:29 PM
G-Body's Avatar
That is the same thing, when you are in EFI Live7 or HP Tuners and go to change the tach output it does not have the # of pulses listed, it has an equation and you can change the number of pulses by changing the variable "n". Its hard to explain, but easy to understand once you see it. I believe that putting in 3 for the n value with either software will make the output a 4 pulse/rev V8 tach signal, but don`t quote me on the 3#, I don`t have any tuning software I was just standing there watching jesse while he tuned my computer with EFI Live7.
Old 05-14-2007, 01:46 PM
daniel6718's Avatar
ok im just wondering i had a local shop tune my car and i believe they said they were using hptuners, but they couldent find what they needed to change, since theyve never done it before, can yall give me a direction to tell them?
Old 05-14-2007, 01:56 PM
the_merv's Avatar
Mine was done with EFI Live..
Daniel- you said that all the people around you had HP Tuners..see if it's not LS1 Edit or something like that..
Old 05-14-2007, 03:14 PM
Rodder's Avatar
Engine->General->Tach Output
Tach Output Resolutions - High Change to 3 for 8cyl tach
Tach Output Resolutions - Low Change to 3 for 8cyl tach
Old 05-14-2007, 04:37 PM
daniel6718's Avatar
im doing this in a 94 so the number will prolly be differant but thats what i needed to know where to tell them to look, i think im going to buy hp tuners, this is bs, im tireg of shelling out money for tunes
Old 05-14-2007, 05:34 PM
the_merv's Avatar
That's the same thing in EFI Live..
Old 05-14-2007, 09:10 PM
Rodder's Avatar
what I posted was for LS1's, don't know anything about LT1.
Old 05-14-2007, 11:31 PM
the_merv's Avatar
That's what I was saying... that is the Pulse Rate we converted my Tach to to in EFI Live.
Old 05-15-2007, 12:47 AM
daniel6718's Avatar
heres s question for you experts, can you change it with ls1edit? if so how?
Old 05-16-2007, 06:04 AM
daniel6718's Avatar
anyone know about ls1edit?
Old 06-24-2007, 08:05 PM
89 formula350's Avatar
still no reply on this? I plan to buy an editing program and this will be one of the things I need it to do
Old 06-24-2007, 08:31 PM
hosspowerinc's Avatar
Yeah I need to know this too. I just got LS1edit but havent received it yet. It better be able to change the signal
Old 06-24-2007, 09:42 PM
67rsss's Avatar
If you don't watn to mess with the computer, the Dakota Digital box works great.
Old 06-25-2007, 03:11 PM
Rodder's Avatar
You can change it with HP Tuners or EFI Live, as I and other people have already said. I don't know anyone using software other than HP Tuners or EFI Live. You mihgt have better luck asking in the Tuning forum here, but I expect they'll just rag you for buying anything other than HP Tuners or EFI Live .
Old 06-26-2007, 01:20 AM
eagleuh1's Avatar
Can hp tuners change the setting in a 2005 Suburban 5.3 pcm to allow a S10 V6 tach to work with the pcm output?
Quick Reply: tach signal-4 pulse to 8 pulse??
