Got tired of the orange LEDs in my odometer/trip meter. . .
1 Post
BTW, you need to be VERY careful when disassembling this. . .and soldiering this. . .and reassembling this. . .
Lots of little things you can do wrong, and then, it gets expensive
And then, since I can't leave well enough alone, did the ASR and foglight switch modifications also. Replaced the original bulbs w/7000 blue LEDs. Will have pictures of that later. basically just like the ones on Keliente's site here. . . http://www.keliente.com/switches.htm
Had flash on. . .
Bright little buggars ehh?
Package as it stands currently. . .more to come!
I have no life.
After posting this on a local board last night, had a friend hit me up to do his 99 TA tonight. Did the odo/trip meter swapout in about 70-80 minutes start to finish! TAs are SOOOO much easier than Camaros because of the dash setup!
Thats tight. how long does it take to do a camaro?? said the ta was quicker. wish i was closer to you. im about 9 hrs away. would love to have that done to my camaro. great lookin change.
Excuse me for my ignorance with the camaro guages ... but didnt they have a "film" behind to give the orange glow? or is that only with the T/A? If i am anywhere near correct could you post up on how you removed the film? i read that replacing the bulb wont help. Cluster looks sick though man!
1 Post
ElanorSS, took me about 2 hours start to finish for my Camaro having not done it before. The gauges for the TA/Firebirds pops out easier over the column.
Gun5, ALOT of finageling(screwing around w/the fitment and custom cutting a bracket to hold the stuff together). Made a post about it some time ago. https://ls1tech.com/forums/showthrea...hlight=humount
Ehatcher, no film. Orange LEDs w/a piece of frosted plexi. Did a friends T/A last night and had same.
Duffster, do you have LEDS in your gauges?
1 Post
Originally Posted by Dave1970
Diffuser,
Just did the odometer LED mod. My odometer lights ups but the mileage and trip numbers are not showing up? Any ideas?
Originally Posted by mycamaroSS
dude that's tight i might do that tomorrow
Originally Posted by Pro-Mo
Are there LEDs that can make them "oranger"
3.8to6.0, Here's some related links for the mods.
http://www.stevendbrown.com/Steering...oControls.html
http://www.ledgauges.com/id26.html
http://www.evlls1.com/interiorlighting.html
http://www.evlls1.com/ls1.html
http://www.keliente.com/LED.htm
https://ls1tech.com/forums/showthrea...=Blue+Odometer
Hope this helps, there's alot of others that you can find using the search with keywords such as blue LEDs, LED mod, Blue gauges, etc.
