MAF VS Speed Density Tune!
I am going to have my ecu (98 ecu) tuned in a couple months. I was wondering how hard is it for the tuner to convert it to Speed Density? What are the benifits of a Speed Densitiy tune? Should I get this? what do you guys think?
I am fine with keeping my MAF. I though I would inquire about the Speed Density tune.
LS1TECH Sponsor
Kleeborp the Moderator™
I'd do a lot of reading if I were you. If you aren't comfortable with the concept of SD by the time you make the decision, just go with a MAF tune. Done properly, they should make the exact same power (as long as the MAF sensor isn't choking the airflow to the engine).
Originally Posted by SSpdDmon
SD is hype unless your car really needs it (usually higher psi turbo apps).
