What do you think of this cam only setup???
getting ready to go with a cam not sure exactly which but really leaning more towards the LG G5X3 out of all ive seen so far.
im going to change some other stuff while im down there so what do you think of the following if you have any experience with any of the stuff i listed let me know whether its good or bad and also if you have any recomendations on any other parts let me know.
*G5X3 CAM
*SLP Heavy Duty Oil Pump/Timing Chain Package
http://www.ws6project.com/user_stor/...9e302e63bbe2e9
*Comp Cams High Energy Hydraulic Roller Lifters
*Comp Cams Hi-Tech One Piece Chromoly pushrods but what size?http://www.ws6project.com/user_stor/...9e302e63bbe2e9
*What valvesprings, retainers, locks, etc. would you run...
the Patriot http://www.ws6project.com/user_stor/...9e302e63bbe2e9
or
the Comp http://www.ws6project.com/user_stor/...9e302e63bbe2e9
*G5X3 CAM
or
You dont need lifters, and if you choose the go with the comp springs, then id just buy the whole package from LG as it would most likley be cheaper than buying everything piece by piece.
well the car just turned 55,000 miles and a few people i talked to said they would go ahead and change the lifters just incase. the dude at comp said to go ahead to because 55,000 may not need them now but around 60,000 they probably will and he also said that with running an aftermarket cam that is kind of aggresive he said it would eat the stock lifters up.
what do you think of this is this a good deal cause its a matched set?
http://www.lgmotorsports.com/catalog...oducts_id=1399
is there anything else i'll need to complete my cam swap besides the timing chain & oil pump that isnt in that kit? do i need to get new gaskets or are they reusable?
http://www.ws6project.com/user_stor/...a4a31777b07e84
is that the balancer bolt needed?^^^
is this a good cam swap kit?^^^
is it just me or does the LG cam kit seem over priced?
http://www.lgmotorsports.com/catalo...roducts_id=1399
