Bronze fork pads for 5 - 6?
Old 02-02-2007, 09:43 PM
cryker's Avatar
Default Bronze fork pads for 5 - 6?
I see a lot of people changing to the bronze fork pads on 1-4 but what about 5-6? I would think you want to do all of them but is there a reason so many only do 1-4?
Thanks
1968 Pro Touring Camaro.
EFI, T56, 4 wheel disk, Hotchkis springs, front and rear, Hotchkis revalved Billstein shocks, Hotchkis 1 1/8" sway bar, and more.
http://www.cardomain.com/ride/2334689/1
Old 02-02-2007, 09:58 PM
ROCNDAV's Avatar
I know the bronze are stronger, but are they also noisier? Do people not go bronze (or is it brass) because they dont shift 5/6 hard and when cruising probably want quiter drivetrain noise?
Old 02-02-2007, 10:04 PM
cryker's Avatar
Well when I did a search for the info I did read that properly installed bronze pads would not effect noise at all. But can't speak from personal experience.
Old 02-04-2007, 10:18 PM
cryker's Avatar
anyone else have any input?
Old 02-04-2007, 11:56 PM
99FormulaWs6's Avatar
You should only need 1-4 but if you've got the extra cash I'd splurge a bit buy all 6 just to not have a chance of plastic breaking off in my tranny.
Old 02-05-2007, 12:18 PM
cryker's Avatar
Well I went ahead and did all 6.
Old 04-25-2007, 08:45 AM
vh14a's Avatar
Non-sponsor - post removed. Please contact Nine Ball or Pro Stock John for sponsorship info.
Old 04-25-2007, 09:05 AM
ls1 joe's Avatar
We normally don't do the 5/6 shift forks just because most customers don't every power shift 5/6. Every Bronze fork pad we have ever used does cause some noise but normally if you have exhaust on your car, you will never hear it.
Thanks,
Amber
Old 04-25-2007, 10:14 AM
A-Dub's Avatar
I only bought the 1-4 pads for my rebuild. When I got inside, the 5-6 pads were toast. It was just as easy to buy brass ones from SixSpeedsinc as it was to try and get some palstic ones, so I bought brass. Haven't got the car back together yet, so I cant comment on noise
Old 04-25-2007, 11:28 AM
SladeX's Avatar
The shifts on my car feel a lot more solid now since putting in the bronze pads. You can definitely feel the difference in the shift, whether you like it or not is a different matter.
The only way I can describe it is the difference between the two is like the difference in pushing in metal on metal versus metal through plastic. The plastic will be softer and smoother.
Old 05-03-2007, 05:18 AM
vh14a's Avatar
Default chech out this link for shift pads
http://www.techvalleymachining.com/2.html
Old 05-03-2007, 05:20 AM
vh14a's Avatar
Default shift pads
I use the tech valley pads in my transmission and have no noise, the car shifts like a dreem!
Quick Reply: Bronze fork pads for 5 - 6?
